Help! Todayz Damage! Thanks
Location: Sydney, Australia Home for none of you rc needs!
Well as the title says please follow the links and help me out!
Rear Bulk Set Pic: http://i117.photobucket.com/albums/o...n/DSC01376.jpg
Front Bulk Set Pic:
http://i117.photobucket.com/albums/o...n/DSC01379.jpg
Gears:
http://i117.photobucket.com/albums/o...n/DSC01380.jpg
OK the pik showing the piece of metal that my mate has cut out for me and i stuck on their was part of the Rear Bulk Set ... and i wanted to know if i can buy that one n the one that holds the front of the pin without buying the diff cases etc etc? And does anyone know were i can get them in alloy. It would be of great help if you could get me a Aust. LHS or one anywere else that will ship to Sydney.
The other pic, that shows that snapped plastic i think it is part of the front bulk set as it is connected to the top half of the front diff case. Does anyone know were i cna purchase this part without purchasing the whole front bulk set.
OK, last but not least there is my gears both spur and clutch etc. They are totally gone just got worse and worse worn out half are melted rocks have been stuck in them etc etc...ok i was wondering wat Gear setup like amount of teeth should i choose to use ??? for both gear 1 on clutchbell n spur gear one n smae for no.2 Thankyou. I do not race and i have a street about 50mt long with a slight curve i normally just race against mates maybe that will help in the no. of teeth i need.
Cheers
Chris
Front Bulk Set Pic:
Gears:
Cheers
Chris
Bump Plz Help!
go and see kellettshobbies in liverpool!
