Old 12-15-2006, 05:50 PM   #1
Default what should i do to lube the motor up before starting
new motor....what precautions should i use to get the ling oiled before starting
indy_rc is offline   Reply With Quote
Old 12-15-2006, 07:34 PM   #2
Serpentd's Avatar
Not sure if I understand your question entirely, but upon 1st start up it helps to put your "breakin fuel" in the carb for sort of a prime. I usually close the throttle fill the carb with fuel then open the throttle to get it into the engine. Other then that you really don't need to prep a motor for initial start with a new engine. It's the oil that is in the fuel that takes care of the lubrication for the liner. I hope that helped. If your question is in regards to something else, let us know and we will get you the answers you need. Good luck!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 12-15-2006, 10:50 PM   #3
If your doing regular maintenance after each run then you shouldnt have to use any kind of lube upon starting the engine.
there is already oil in the fuel, best protection would be not to run it to lean, should be a light trail of smoke when your running, unless of course money is no object.
AKSHUN is offline   Reply With Quote
Old 12-16-2006, 12:00 AM   #4
DogboneS's Avatar
Trader Rating: 20 (100%+)
As said before use a high oil (not nitro) content fuel. Loosen the the glow plug till air can escape a little. If using a bump box hold a finger over the exhaust tip and give the motor a few spins on the box till it sounds like fuel is going thru the motor. You may have to open the throttle a small amount to allow fuel thru the carb. Your lubed now. Throw the glow tool on or tighten the glow plug then use the glow tool and see if it'll start. Some high compression motors start easier with the plug a little loose. Once its running on its own tighten the plug. BTW from the factory most motors come with some oil film still in them from assembly lubes, so your intial spins of the motor are not bone dry.
DogboneS is offline   Reply With Quote
Old 12-16-2006, 02:39 AM   #5
gashuffer's Avatar
Trader Rating: 48 (100%+)
Just start it up and run it rich for 6 tanks at 1/4 throttle then start leaning it out.By the 8 tank let her rip
gashuffer is offline   Reply With Quote
Old 12-16-2006, 04:59 AM   #6
Pattojnr's Avatar
Trader Rating: 19 (100%+)
when i run in an enagine, i use the fuel i will use when im racing it. for starters, i preheat the engine to relieve the stress on the conrod, then if you remove the glow plug and prime the fuel to the carb by the starter box, so its well lubed. then make sure there is still heat in the engine or i preheat agian with the glow plug installed. i then start the engine and let it idle for a tank. let it cool down to room temp thoroughly, then repeat the process again for another tank. after 2 tanks, a preheat of the engine is all i do till its run in at the track for another 6 tanks. replace the glow plug and then race tune leaning little by little for another 2 tanks. hope this helps, as im yet to destroy an engine by doing it this way. they loose compression first and get sluggish. the trick is to keep lots of fuel going through it at all times, and dont run too hot or cold, both ends of the scale are not good. bout 180f i run them in at. cheers.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
to lube...or not to lube! builthatch Electric Off-Road 7 11-11-2006 08:39 AM
Lube Jez81 Rookie Zone 14 05-19-2006 06:25 PM
LUBE -OIL AND ???? impdog Nitro On-Road 3 05-04-2006 10:48 PM
hard time starting motor with starter box NTC3Kitty Nitro On-Road 4 07-24-2005 09:15 AM
How much Diff Lube do you use? Ducati-Rider Nitro On-Road 0 02-08-2004 08:53 PM
SEO by vBSEO 3.5.0
