Old 12-14-2006, 03:28 PM   #1
Quietroit's Avatar
What the different between kyosho car
what the different between kyosho v1rrr evo wc and v1rrr wc. And is it a conversion kit to change the v1rrr wc to evo wc. And where can you buy at.
G4rs 09|3pk| KO KO PROPO
Quietroit is offline   Reply With Quote
Old 12-14-2006, 04:54 PM   #2
bighurt98's Avatar
Default Differences?
  • Modified material for the gears and main shaft has further improved the strength of the drive system.
  • Revised shape of the top of the rear bulkhead (not shown) has increased choices for the rear inner camber link positions from 2 to 5. The extra settings allow more range of camber change ratio.
  • New compression rate of the standard 13mm (I.D.) shock springs is more suited to most track conditions. Shocks have new 2 hole pistons in front as well as rear. Shocks have the titanium shafts like the Evolva. Also new Square top diaphrams to control damping and leakage.
  • Polished finish on both sides of the brake rotor and Teflon brake pads promise exceptional braking power and feel.
  • Revised arrangement of brake rotor and pulley compliment the new material for the brake hub to produce constant braking power from the start to the finish line.
  • Top deck is now for a vertical trottle servo. The deck has been opened up top to have easier access to steering servo horn. The steering servo plastic mount has been milled out on the top to allow wiring to pass through for servos, switch and personal. Also, a new hole has been drilled into top deck to help center your steering and then you can attach the servo horn to servo.
  • New brake pads for softer feel. The brake lever is now 90 degrees to chassis for nice brake action.
All new additions are excellent and all can be purchased as part of a conversion. I got my conversion from Kyosho America. The Border RC has the conversion but will cost more due to shipping costs(mostly). These few modifications just enhance the performance of this chassis and gives you more tuning options for more types of tracks.
Serpent 748/Matrix Tires/Novarossi
Serpent America/Desoto Racing
Murnan Modified Motors
Team Gravity
bighurt98 is offline   Reply With Quote
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 10:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 06:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 05:07 PM
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 4 09-24-2007 07:46 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 10:26 PM
SEO by vBSEO 3.5.0
