Old 12-08-2006, 01:32 AM   #1
Default HELP 2
Hey, a while ago i set a thread about my o.s 15 pull start engine,
G'day, I need serious help, i'v just bought a Bv-1 Chassis with o.s 15 pull start engine, i ran it in as required and have just changed fuel to 20%, The car is only four weeks old now and it won't start. I couldn't get it too fire so i changed the tuning and now nothings right tune wise!? I'v checked The GLow plug, warmer, fuel and pulled the motor out and nothing seems wrong. I cant fugure it out??? Can anyone help?
Ok, i went back to 5% nitro, set the fuel, made sure the warmer was good, and put a new OS 8 plug in and it still wont even fire, it just turns over? any suggestions?
outlaw19 is offline   Reply With Quote
Old 12-08-2006, 07:45 AM   #2
if nothing seems wrong with the motor, then your not getting fuel into it.
try to prime the line by putting your finger over the exhaust stinger and pull the cord a few times, you should see the fuel go through the tubing.
you should be able to get it fired then.
AKSHUN is offline   Reply With Quote
SEO by vBSEO 3.5.0
