Old 11-23-2006, 04:59 AM   #1
Taylorm's Avatar
Default Old Fuel?
-I have an Associated GT that has not been ran in some time, and i would like to fire her up today. The fuel i have for it is probably 3 years old. Will this fuel still be good, or should i buy new? It has been stored in a dry basement, so i don't think there should be any water in it. Would YOU use it?
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 11-23-2006, 05:42 AM   #2
Trader Rating: 89 (100%+)
Default Fuel
If it doesn't have water in it it is still ok. Alky will get cloudy if it has water in it. Hope this helps.
latemodel13 is offline   Reply With Quote
Old 11-23-2006, 05:44 AM   #3
ssuga20's Avatar
Trader Rating: 48 (100%+)
Default old nitro fuel
IMO, I would recommend to try a little amount and if the engine runs OK, I would use it. I've been using up some nitro that is 4 years old with no problems.
If you have some fresh fuel, I would run that first to make sure everything is good to go and then try a small amount of the old nitro to compare results. If the fuel is no good, you can always dump it out of the tank and use fresh fuel. Hope that helps.
ssuga20 is offline   Reply With Quote
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 06:34 PM
Tower Hobbies Power 20% nitro fuel VS Trinity Monster Brew 20% nitro fuel? needhelpPLZ? Nitro Off-Road 1 07-23-2007 05:01 AM
30% fuel motohead24 Electric Off-Road 14 02-08-2006 02:36 AM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 09:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 04:44 PM
SEO by vBSEO 3.5.0
