Old 11-13-2006, 07:56 AM   #31
Send a message via MSN to ZELOKO
Originally Posted by Seisick
you can find valuable info on the mtx4 nitrokb database. there´s a link on the mtx4 thread.
for the record I only use 52 spurs for several hours now.
Please give us this link
ZELOKO is offline   Reply With Quote
Old 11-13-2006, 06:34 PM   #32
JLock's Avatar
There is another issue that no one seemed to have addressed that I noticed with both my MTX3 and MTX4 with the 0.8 pitched gears. I noticed that I quick stripping the second gear once I made the gear split the same as the gear split on the clutch bell. So, if I am running a 4-tooth split on the clutchbell, I run the same on the spur gear and so on. However, I have noticed like everyone else that the 52-tooth second gear does seem to strip out very easily.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 11-14-2006, 07:41 AM   #33
Seisick's Avatar
lots of tips.
I´ve tried with 5 and 7 teeth difference on both pinions and gears and no problems, that´s a 2 teeth apart, and used the 52 spurs and no stripping. no one in my club has stripped since finding out that the gears should be perfectly aligned and with a shim on the 2 speed pin or a bit of dremel on the brace.
any help please pm
happy racing.
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-17-2006, 04:12 PM   #34
BIGTACO's Avatar
As suggested, I switched back to the 53 tooth spur. I also mated my second gear pinion to the spur with no angle deviation before sliding the first gear spur on. Since then I have not had any stripping. **Looks around for some wood to knock on but finds none so knocks on head**
BIGTACO is offline   Reply With Quote
Heaps of Stuff, MTX4 aRTR, mini parts, radio, photography gear... Ashley Cobb Australia For Sale/Trade 9 04-15-2008 02:46 PM
NT1 720 MTX4 Gear module? ioxqq Nitro On-Road 1 03-14-2008 07:58 AM
RC gear keep stripping please help! qdv Electric Off-Road 9 05-06-2007 09:45 AM
Paint stripping jeffrock Electric Off-Road 3 02-09-2005 08:48 PM
rims stripping beetlebz Electric Off-Road 7 10-05-2004 08:35 PM
SEO by vBSEO 3.5.0
