Old 10-18-2006, 12:44 PM   #1
Default Turbo
The compressor section is identical in function to any centrifugal supercharger, the only difference is that the turbine section of the turbo drives it. One thing to know is that turbocharger compressor sections are (generally) significantly smaller than their supercharger cousins. This all has to do with efficiency and the chosen method of powering the compressor, so just know it's the reason why you see turbochargers spinning such high RPM when compared to their centrifugal supercharger cousins. It's all about necessity.
This section bears a strong resemblance to the compressor section for a reason; it basically functions the same but backwards. The two main parts are the turbine housing and turbine wheel, and if this is an internally wastegated turbo, the wastegate also resides here (there will be more on that later). As exhaust gasses quickly move out of the cylinder and into the exhaust manifold, they are routed into the turbine housing's scroll. If you understood the flow of air through the centrifugal compressor design discussed earlier, here it's just the opposite occurring. As the hot and rapidly moving gasses attempt to find an airflow path through the turbine housing (with the ever decreasing scroll area), they come in contact with the turbine wheel on their way to the center outlet of the housing. As they rush through this airflow path and into the exhaust downpipe, they spin the turbine wheel, imparting a portion of their kinetic energy to the turbocharger. Especially notice that with this design comes variable RPM, the turbocharger itself is not physically strapped to any rotating part of the engine. This makes many different turbo shaft speeds possible at a single engine RPM, which is where the system's basic performance characteristics and tunability are born.
Although I say "basic" here, know that this is pretty much an oxymoron when dealing with turbos. There is nothing basic about a turbo system, as many different things concerning engine operation need to be addressed. The basic turbo system should come with a bunch of different things, and few systems effectively address all these unless your car was originally equipped with the system. Here they are, in no particular order (with the little things like vacuum line omitted), and notice
1- turbo
2- exhaust manifold for turbo
3- wastegate
4- blow-off valve (aka bypass valve)
5- lines for oil supply and return
6- intercooler (optional)
johnfedrer is offline   Reply With Quote
Old 10-18-2006, 01:09 PM   #2
Send a message via AIM to apollo
what is the point of this thread if i may ask
apollo is offline   Reply With Quote
Old 10-19-2006, 12:12 PM   #3
BIGTACO's Avatar
The point is to learn about turbos in real cars. But wait, RC cars aren't real cars. I think I know what the intent of the post is now. Its johnfedrer's attempt to try and trick us into believing RC cars are real cars. Well, you almost got me Mr. Fedrer, but you will have to try harder than that
BIGTACO is offline   Reply With Quote
Old 10-20-2006, 06:29 AM   #4
schufflerbot's Avatar
he got me.
schufflerbot is offline   Reply With Quote
Competion Electonics turbo 35bl stealth ed, turbo 30, Pitbull x3 & Novak Millenium Pr pablo101 R/C Items: For Sale/Trade 29 10-27-2008 08:44 AM
Competition Electronics Turbo 35 BL stealth Edition And Turbo Flex 30 NIdaho Mudder R/C Items: For Sale/Trade 1 06-10-2007 06:55 AM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 09:10 AM
Wanted, metal lathe, milling machine, Turbo matcher, turbo Zapper lazarus Other Items: For Sale/Trade or Wanted to Buy 1 05-15-2003 11:20 AM
Tunning issue with MR12 turbo and RD turbo pipe PG Nitro On-Road 12 05-05-2003 09:19 PM
SEO by vBSEO 3.5.0
