Old 11-06-2001, 04:55 AM   #1
no power from the engine!
hi i've just bought a thunder tiger ts-4n sport and it has a bit of a problem.
when i got it, it was 100% built so i decided to start braking in the engine.
once it started i noticed that it revs right up but the cogs do not turn.
when i try to move it accross the floor there is quite a bit of drag.
any ideas whats wrong and how to sort it.
headsy is offline   Reply With Quote
Old 11-06-2001, 02:53 PM   #2
Check your brakes. They might be dragging and that will give the drag your experencing. To test if it is you brakes try giving it some throttle and role it across the ground. If you notice a decline in drag its your brakes so rejust them.
There is also two screws that hold the brake pads on if they are two tight they will also give you drag. Losen them if the first way does not work.
Hope this helps.
DanR is offline   Reply With Quote
Old 11-15-2001, 09:13 PM   #3
check that clutch. it usually melts once overheated.
joyrider is offline   Reply With Quote
Engine Max Power XL3 .12 with pipe max power efra 2602 dht R/C Items: For Sale/Trade 22 11-02-2008 11:57 PM
fadding engine power hobdog Nitro Off-Road 14 09-11-2008 02:29 PM
MAX POWER .21 ON-ROAD ENGINE kurtcash Australia For Sale/Trade 2 08-20-2008 12:18 AM
CEO Power mods , anyone done the engine mod? atebit Nitro Off-Road 39 03-15-2008 01:25 PM
Max Power M5B .21 engine.....Up again. audio1 R/C Items: For Sale/Trade 8 10-25-2007 04:52 PM
SEO by vBSEO 3.5.0
