Old 02-07-2003, 07:41 PM   #1
Default HOw to probally break in and Engine?
How would you break in a OS CVR .12 ? what is your needle setting? for high end and Idle and Low end. How many tanks to Run when breaking it in? Im just wondering cuz i just rebuilt my Engine thats why i wonder.
Yokomo_King is offline   Reply With Quote
Old 02-07-2003, 10:09 PM   #2
pkranger63's Avatar
It should tell you in your engine manual. If you don't have it you can look here...
pkranger63 is offline   Reply With Quote
Old 02-08-2003, 12:53 AM   #3
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Plenty of information already on this topic:
break in an engin
proper way to break-in an engine???? (LOT of info on this thread. . .)
Go through these first.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-09-2003, 06:12 PM   #4
torchedlh's Avatar
Send a message via AIM to torchedlh
scroll down to you find "Engine Break In And Tuning For The New and Experienced Racer: "
torchedlh is offline   Reply With Quote
Old 02-11-2003, 05:15 AM   #5
Send a message via Yahoo to nkay
What i used to break my engine in, and I think ive gotten much better results was placing the engine on plywood with a propeller. I let it run at idle for about a tank, with little blips of the throttle to clear the fuel out. After my 4th tank leaned it out a bit and had it run around half throttle. In between tanks i let the engine cool to room temp. Ive gotten so much more power doing it that way then breaking it in the car.
nkay is offline   Reply With Quote
Old 02-11-2003, 09:31 AM   #6
Tech Chat Moderator
TheRagunCajun's Avatar
Well, as we discussed in another thread ALOT, your best bet is to follow directions that came with the engine. If you want to do somethign else, refer to the a page or 2 back. Im sure you check it out before startnig this thread.
Wow these forums have gotten popular since 02!
TheRagunCajun is offline   Reply With Quote
Old 02-11-2003, 10:45 AM   #7
popsracer's Avatar
I have also used the propeller method of engine break-in, however the Carb is in the way on most RACE R/C car engines to do this. All of my RACE engines have been broken-in the car by idling 1-3 tanks, then driving all future tanks, with a complete cooldown between tanks. By tank 7-9 the engine is usually close to being in full race tune.
As long as you follow SOME kind of break-in proceedure before going full tilt, you should be fine.
popsracer is offline   Reply With Quote
engine break-in help r/t Rookie Zone 22 09-11-2007 07:02 PM
OPS engine break-in maresma Onroad Nitro Engine Zone 2 10-14-2006 12:43 AM
Engine break-in dct147 Nitro On-Road 21 07-09-2005 11:20 PM
.12 engine break in... elmar66 Onroad Nitro Engine Zone 2 06-30-2004 03:08 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
