Old 02-05-2003, 03:26 AM   #1
Default Sx 12 Re Temp
Hi what temp should the Nova Mega SX 12 RE Turbo be running at, i have heard that they need to be atleast 240 deg to wake the motor up. is this true?
MDS is offline   Reply With Quote
Old 02-05-2003, 06:29 AM   #2
modellor's Avatar
What has temp got to do with it. I have never used a Temp Gun in 16 yrs racing professionally. I couldn't care less what temp my engine runs at. You will know by listening to it whether it is running sweet or not.
And as far as I know this is the preferred method of Motorman (Dennis Richey) who does all the great engine modifying.
But between 220 and 240 will work.
modellor is offline   Reply With Quote
Old 02-05-2003, 07:51 AM   #3
Send a message via AIM to deanspoors
Default NO!
the answer is NO! MDS so i suppose a little leaning of your engine wont make it whip mine ... if you want to beat mine try 40-50% nitro ha ha ha
deanspoors is offline   Reply With Quote
Old 02-05-2003, 07:58 AM   #4
Nitro Tech
dino.tw's Avatar
Yes,a veteran of nitro engine isn't need temp gun.Because they can know the negine's condition by other way like Listen,Smell,Touch,Feel....etc.I used my finger instead of temp gun because I'm too lazy to take it out.When I feel pain,it's over-heat.haha....
But if you don't have a lot of experiences,temp gun is a good friend of you.Also,220-240F is good.
dino.tw is offline   Reply With Quote
Old 02-05-2003, 09:13 AM   #5
Tech Chat Moderator
TheRagunCajun's Avatar
Touch, feel, smell?? Oh come on now. And a properly tuned engine wll feel hot to the touch. I use a drop of water myself. Also i tune by how it runs.....which is important. I also like to see smoke but alot of smoke doesnt mean your engine is running rich. BTW RB's and some toehrs run as high as 280F.
BTW, what's the proper way to do the drop of water test. I put a drop near the plug and see what's what. At my current seting, it just stays there I think it's near the plug and not the top of the head cuz my water never boils on the top of the head.
Wow these forums have gotten popular since 02!
TheRagunCajun is offline   Reply With Quote
Old 02-05-2003, 12:00 PM   #6
Send a message via Yahoo to TambokGT
I have the same engine. When breaking in the engine run temps around 220F max....after 8 to 10 tanks you can go higher up to 260F . Racing temps go up to 250 to 260F......just watch for that blue trail of smoke......no smoke...very BAD.
TambokGT is offline   Reply With Quote
Old 02-05-2003, 10:26 PM   #7
JUN is offline   Reply With Quote
Old 02-05-2003, 10:52 PM   #8
Im2lazy's Avatar
A temp gun is pretty good when you've got an engine that seems to have a bad low end setting. If at idle your temp stays around the same or increases, your mixture on the low end is lean. If it slowly drops, then it is fine.
I don't own one, but when the weather changes drastically or when I change my plug from a really old one (covered with crud because I'm too lazy to change it) then I might borrow one from a friend. Temp guns don't help to fine tune the main neddle settings much, and I bench tune well enough in the pits to only require about 1/16 to 1/32 turn out on the track, so I don't have a good enough reason to spend 100 dollars on one.
A temp gun is also good for 20 minute or longer races because we generally run five minute races, so just to be careful I might check the engine with a temp gun.
Im2lazy is offline   Reply With Quote
Turbo Head Temp VS. Regular Head Temp SlickZero.com Nitro On-Road 13 08-18-2006 04:10 PM
DURATRAX TEMP GAUGE / VENOM SMART TEMP AND VENOM FAIL SAFE tmaxxking R/C Items: For Sale/Trade 13 07-04-2006 12:46 PM
FS NIP VENOM SMART/ TEMP (fail safe and on-board temp gauge) factory racer R/C Items: For Sale/Trade 7 07-02-2006 10:49 PM
Raytech mini temp temp gun Art Jensen R/C Items: For Sale/Trade 4 11-19-2005 07:31 AM
Wanted Temp Gun Or Temp Device BC_R/C_RACER R/C Items: Wanted to Buy 4 05-29-2003 06:35 AM
SEO by vBSEO 3.5.0
