Old 09-13-2006, 05:43 PM   #16
Thx for your explanation, Duneland!
raceblast is offline   Reply With Quote
Old 09-13-2006, 06:09 PM   #17
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Good info guys! Keep it coming!
Wanabrc is offline   Reply With Quote
Old 09-13-2006, 10:58 PM   #18
Sandra's Avatar
Hello all, what would be the effect on the car, if the rear tires are trued with 2 degrees of pre-camber as opposed to 1.5 degrees. Thank you in advance.
Sandra is offline   Reply With Quote
Old 09-14-2006, 05:18 PM   #19
duneland's Avatar
The angle you cut into the tire, should be somewhat less than the neg camber that you run (for most situations). The goal is to get the angle on the tire, that would eventually wear into the tire based on your camber settings. Due to the effects of cornering forces, the neg. camber settings on the chassis need to be a little more than what you pre-cut in the tire. Check the angle on the tires after a tank of fuel has been run & see how close it is to what was cut into the tire.
duneland is offline   Reply With Quote
Measure First, Buy Second >.< shurcooL Electric Off-Road 8 08-06-2008 10:15 AM
Someone to measure a truggy cvd K.Copeland Nitro Off-Road 1 08-22-2007 11:31 PM
What is Droop and How do you measure it BGrcracer Electric On-Road 21 06-08-2006 08:32 PM
measure toe in/out independently raceblast Electric Off-Road 7 12-17-2004 06:29 PM
how to measure a comm onnetz Electric On-Road 12 08-16-2004 12:07 PM
SEO by vBSEO 3.5.0
