Old 08-29-2006, 07:11 PM   #1
Default Stage D two speed conversion
I did some searching and didn't find exactly what I was looking for. I bought a used rs4 rtr3 and ordered the stage d conversion. I did the complete swap and ordered the two speed because it had a single speed origanally. The instructions showed the two speed so I went with it. It has the 15fe motor and now the two gear housing on it. So the larger gear on the motor is contacting the #47 gear on the two speed. I tried to remove the larger gear on the motor so I could turn it around but it is screwed on so tight. The reason I wanted to turn it around is because there is a bevel on the edge of the gear and I believe that would give me the clearance I needed to run both the gears instead of contacting the two larger gears. I tried shiming the gears on the tranny and it just made the gears real tight. I'm lost. My next choice is to file the motor mount holes so I can adjust the positioning. Any suggestions?
srt4 is offline   Reply With Quote
Old 08-29-2006, 07:28 PM   #2
Send a message via AIM to apollo
so basially you are trying to remove the 2nd gear pinion? take 2 pairs of pliers and turn them the opposite way, jsut remember to take the first gear pinion off first
apollo is offline   Reply With Quote
Speed Merchant Rev 4.5 conversion pod Mart42 R/C Items: For Sale/Trade 3 10-27-2006 04:19 AM
Nitro TC3 2-speed Conversion STAN STICKLER Nitro On-Road 5 02-27-2005 05:33 PM
Single stage soft foams or dual stage firms??? WheelNut Electric Off-Road 3 04-28-2004 02:29 PM
red Alex Barracuda - with Xenon stage 2 conversion racer R/C Items: For Sale/Trade 15 04-17-2004 11:17 AM
3 speed conversion for t-max TrickedMGT Monster Trucks 0 03-27-2004 07:57 PM
SEO by vBSEO 3.5.0
