Old 08-25-2006, 12:21 AM   #1
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Default How to replace the one-way needle bearings for G4S?
guys, m thinking of replacing my one-way needle bearings on my G4S, but have no idea how to remove them. can anyone help? btw, are both bearings the same? coz i can only see HF0612 INA Germany on the housing on one of them (hexagon shape). the other one has a round housing with no part no.
actually how do u know when needle bearings need to be replaced? coz my car spins 360degree at few particular heavy corners of a track, n that my frenz told me that my 1-way is damaged. so we tried to stuff the pins in as solid axle, and it ran fine.
pls assist
uniquexme is offline   Reply With Quote
Old 08-25-2006, 02:27 AM   #2
itchy b's Avatar
your best bet is to just go and get a new one way diff as when you try to remove the bearings you'll most likely damage the casing.
for thew cost of the bearings you should be able to get the whole diff
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-25-2006, 02:54 AM   #3
wallyedmonds's Avatar
get a new one dude.
wallyedmonds is offline   Reply With Quote
Old 08-25-2006, 04:51 AM   #4
nitro_racer23's Avatar
mate just get a new one heres the partnumber
K1409 G4 & V1R Lightweight One-Way...
if you can lock the other one up then you will have a front locker
nitro_racer23 is offline   Reply With Quote
What should I replace my DSM Rx antenna with? RC8 Radio and Electronics 9 07-11-2008 01:25 PM
How do I replace the front and rear main bearings? rcjunky10 Nitro Off-Road 27 04-01-2008 07:10 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
brushless what to replace Rasmus TbEvo IV Electric On-Road 3 01-22-2006 09:09 AM
Middle Needle or Spray Bar Needle tuning tips? FACTION95Si Nitro On-Road 12 12-22-2001 01:33 PM
SEO by vBSEO 3.5.0
