Old 08-15-2006, 02:15 PM   #1
Thedub88's Avatar
Default Engine overheating! HELP!!!!
I have a HPI RS4 18SS with a custom cold air intake with a RB Inovations cone filter and a Silver Bullet TSAIS custom exhaust. I'm running a medium plug with 10% nitro.
After about 3-5 minutes of run time, my thermal fail safe (set at 260) Turns on. I tested with hand held thermo, both temps the same.
I tried richening up the mix, got a good blue smoke trail, but still hits 260-280 degrees. I also made sure I had good air flow over head, I cut holes in front and back windows and I removed the grill.
I ran out of ideas please help!!
Thedub88 is offline   Reply With Quote
Old 08-15-2006, 06:05 PM   #2
Send a message via AIM to apollo
first of all those RB intakes are horrible for filtering small particles out
check your fuel line to see fi there is a bloackage, make sure there are no leaks anywhere, if you are richening it up and its not changing it sounds liek there is no change in fuel flow therefore meaning a blockage
also you can run higher nitro for better power, i would prolly never run 10%
apollo is offline   Reply With Quote
Need help with engine overheating. rdsoxfn Nitro Off-Road 4 08-21-2007 06:09 PM
Engine Overheating - Change of wheel Size? Aceboy Electric Off-Road 6 06-05-2006 08:32 PM
Engine overheating: reasons? milen Electric On-Road 28 10-09-2005 06:53 AM
Overheating... Please help gregor Nitro On-Road 5 05-26-2004 12:10 PM
engine overheating? 92tsiawd84 Rookie Zone 5 08-14-2003 03:01 PM
SEO by vBSEO 3.5.0
