Old 08-07-2006, 02:20 PM   #1
Default help with clutch plz????
sorry if iam asking a question thats been asked before. done a search but could not find what iam looking for.
i had done a few repairs and took it over the carpark for a test run( not the best place but the tracks an hour away and i want to see if the repairs were ok)
had it running fine for about 10 mins and was about to pack it up, happy the work i had done was ok.
i was nearly at a stand still and the thing just reved high and drove right into a wall
was only a few feet so it did not get upto speed and after looking it over i cant see no damage
well apart from the wheels only go clockwise when they used to go both ways, so i took the gears of and i guess what is the clutch shoe? is stuck in its housing in an open position where it is normaly closed ie no gap and is not stuck in its housing(check pic please)
is this broke??
if so wat do i need too replace, or is there a way to get it closed again???
iam thinking its stuck in second or somthing so would running it again fast enough for 2nd to kick indo the trick, will it go back to 1st getting it back to normal???
please advice asap as i wanted to goto the track tomorrow but i dont now wats going on
cheers for your replys
dick dastardly is offline   Reply With Quote
Old 08-07-2006, 04:00 PM   #2
Trader Rating: 89 (100%+)
Default Two speed
It's an easy fix. On the shaft that the shoes ride on there is two flat spots. If you hold the shoes and turn the center it will click back in place. Now the fix is to turn the setscrews in the center of the shoes till you just see a gap in between the two. Then back the setscrew out till the gap just closes. What happens is if not kept in adjustment the ball gets wedged in between the shaft and keeps it locked in second. Hope this helps!
latemodel13 is offline   Reply With Quote
Old 08-07-2006, 04:20 PM   #3
Default my hero
cheers worked a treat!!!!
i would of hated to take up this hobbie 15 years ago,no net and i dont know any1 that dose this..
thank you very much
you been a grt help
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 09:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 12:34 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
SEO by vBSEO 3.5.0
