Old 07-27-2006, 06:24 AM   #1
Default Camber out / Elevated Camber
Anyone care to explain to me exactly what this is?
I know some people set up camber on their cars when the car is on the ground and when it is elevated , Kyosho terms this 0g and 1g I believe.
What is the point of setting up camber when the car is elevated and its effect on handling?
Also I don't understand how 0g and 1g camber settings can be made independent of each other , when they are adjusted at the same points - the pivot blocks or upper linkages. So changing one would effect the other , or cancel each other out no?. Ie if you add 1 degree of camber at 0g and then minus 1 degree at 1g , wouldnt you be left with 0 degree camber at 0g too?!
Help! Thanks.
ronestar is offline   Reply With Quote
Camber? When to use and when not to use? nitrobeast Electric On-Road 14 07-15-2008 08:03 AM
how to set my camber to zero aquito Electric On-Road 4 05-03-2006 10:00 PM
how to set camber ? Blaze1 Rookie Zone 5 05-04-2004 05:37 AM
Camber Help? doublest Electric On-Road 6 05-03-2003 05:33 AM
camber wahturi Nitro On-Road 2 12-20-2002 03:17 PM
SEO by vBSEO 3.5.0
