Old 07-17-2006, 01:15 PM   #1
Default Got a question!
Ive got an old Duratrax Street Force GP that I wanted to mess around with again. Im going to drop the Velocity .15 thats on it and throw an OS .12TZ in its place instead. My question is this, Can I use the same small block motor mounts that the .15 uses? I was just gonna order another set and use those, but Im not too sure if it will work.
tenthscale is offline   Reply With Quote
Old 07-17-2006, 11:51 PM   #2
Carbonfi_dragon's Avatar
Hi there,
I have 3 different OS TZ .12 engines, and the lug dimensions of the crankcase are 31.4x11x49.8 (mm). I am told that they are the standard small block dimensions, and most engines up to .18 size all use the same dimensions. This should mean that you will be able to fit the engine in.
Carbonfi_dragon is offline   Reply With Quote
Old 07-18-2006, 09:45 AM   #3
Thanks alot, I did check the dimensions and they do work fine. I appreciate it. I know it was pretty much a standard, but with that Streetforce GP, you can never really tell.
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 05:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 08:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 11:46 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
SEO by vBSEO 3.5.0
