Best Radios and servos
#16
Originally posted by Corse-R
InitialD:
Followed the thread, but none has given me instructions about this (have three 297FZ receivers here that I cannot use) how to disable the HR mode response and needed to buy the new 301F receivers.
I shitted myself and sobbed on what I was thinking when I decided to change from my trusty Mars to Mars-R. Blue led is so intense that hurts your eyes and distracts everyone at the rostrum (put a dab of Serpent putty) and no need for the 25 model memory going from a 10 model memory.
InitialD:
I would not know if the high response mode needs to be switched off or it can automatically detect to use or not to use high response mode.
#17
Futaba 3pk or Ko Propo Mars-R
Thanks for all the replies. I never even heard of KO Propo. So which do you guys suggest the KO or that new Futaba. And also where Would i buy the KO Mars R on the web
#18
i also have mars r and love it plan to use it for a long time
servos ko futaba or jr seem to all be good
hitec fail somewhat often luckily mine are still under warranty
i have found ko at bruckner hobbies search for them online
if you have large hands the mars r may not be the right radio for you but unless your hands are pretty large it is the best radio ive ever held
250 price range includes mars r and m8 futabas new radio is more expensive but possibly the best of all in adjustabiltiy
#19
corse-r are you saying that you have tried to use the old recievers and they didnt work?
i was hoping they would work i was planning on getting a novak xxl for a spare reciever to save a little cash
guess i should play it safe and get another 301F
anyone using ko stuff ever have any radio problems?
i had a set of crystals go bad but i think it was a one time deal but i figured id ask
i noticed at the track last summer a few really old looking ko radios so i figured that they lasted a long time
#20
i'm not saying the Mars isn't a good radio but you really don't see it around as much as Futaba, if you need an extra receiver or something it alot easier to get Futaba stuff, also I just got the new 3PK and it the easiest Controller to Program I have ever seen. it also comes with rechargable controller pack, the piece that drops the steering wheel down, and a charger for the controller/receiver packs. Not a bad deal.
#21
I got another receiver 301F receivers in case that the main fail someday.
'Vintage' KO Radios have something on their own. A track buddy nowadays (2003) uses the same KO EX1 Radio that bought on 1992 (That's a very loooong life for that radio). More rugged, less power drain (don't have bells and whistles) much more sturdy and reliable, only 'two' problems, KO Propo don't repair that system if someday fails, works on AM.
#22
Jason:
If my previous experience with KO can serve you as an example I'm a loyal customer of them since 14 years and plan to continue.
On 14 years only had two problems, one radio fall from the rostrum and seld disintegrated on 1000 parts and 4 months ago my unique 301F receiver, misteriously went bad. KO UK changed me for a new without charge some weeks after (Meanwhile I needed to bought a Backup one, now I have two).
#23
thats very good to hear the mars r is my first ko radio
the crystal thing is the only problem ive had
i have just never had a crystal fail before
maybe i was due
have you ever had a crystal become loose?
do you think if i bent the prongs somehow
maybe i was due
#24
maybe i was due
maybe i was due
If you have got a great smack in your car, possibly affect to the cristal, check and if fails, discard them (say them goodbye with a longnose plyer or a 'precission instrument' called hammer )
#25
i dont think it was hit i was just breaking engine in while in a parkinglot
i was running my mtx-3 and i thought it was isolated from vibration by the 2 grommets that support the reciever mount
i was right near a train station at the time i wonder if the high voltage lines overhead could have made an effect i do remember the train coming past near the time of failure
as far as crystals coming out i wrapped a rubber band around it
i may eventually put a reciever box onto the car thus eliminating the possibility like on my 1/8 buggy
#26
Futaba 3PK follow up...
To follow up on the questions raised with HRS, Digital servos, and receivers. I looked this up and here's the deal:
THe 3PK has 3 modes: HRS, PCM, and FM. This is set on the radio, so you will be able to use any kind of FM receiver. For PCM mode, you will need the R113JE(?) PCM receiver - the one that comes with the 3PJS. To run in HRS mode, you will need both the R203HF receiver that comes with the 3PK AND digital servos, since as per Futaba, Digital servos are the only kind capable of responding fast enough to the HRS signal. Otherwise, I would think that you must run in FM mode (the R203HF does not have a PCM mode). This was the only bit of info I couldnn't confirm. The other possibility would be that the receiver would run in HRS mode, but the servos would not respond as fast as expected. Whew!
