Old 06-26-2006, 02:08 AM   #1
Default I think I have an air leak?
Hi all,
Just so you know what this is a problem with I have an old Kyosho V-one S with the stock GS15R engine. This all started a few days ago when I started the engine and it was idling high. I look at the gap in the carby at idle and it looks like its normal position. So I pull the carby off and check the o-ring and the sealing surfaces they are all clean and dirt free, no nicks in the o-ring everything looks fine. I check the backplate and it is tight and once again the seal looks fine. So I decide that for whatever reason the idle has changed and maybe I should just close the carby idle slightly then everything will be ok. Yep the engine idles fine now but the carby is closed completely and every time I back off after full throttle the engine flames out.
I know my carby shouldn't need to be closed to idle. But I have no I dear where the leak could be or even if it is an air leak. Any ideas?
Dishy is offline   Reply With Quote
Old 06-26-2006, 03:38 AM   #2
Pattojnr's Avatar
Trader Rating: 19 (100%+)
try to richen the bottom end. it is possible that the climate is much colder than when you run the last time. the more dense the air (the colder it is) the more fuel needed hence it may be running lean at idle causing the idle to be higher than normal.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
air leak mjnp06 Onroad Nitro Engine Zone 3 10-08-2007 09:59 PM
Air leak help Mustang2 Electric Off-Road 1 10-29-2006 12:35 PM
Nova Rossi engine Air leak or fuel leak? Solara Nitro On-Road 15 01-21-2005 03:00 AM
Possible Air leak? HELP! Smoke21 Nitro On-Road 2 08-06-2004 11:25 AM
Is it a leak??? hicheef Onroad Nitro Engine Zone 1 06-28-2004 12:49 PM
SEO by vBSEO 3.5.0
