Old 06-11-2006, 08:42 AM   #1
British Menace's Avatar
Default Spektrum Pro. Stock & R3500 RX
Hi All.
I started this thread as I could not see one dedicated to this system on here. Except the R3500 RX. Sorry. Just found it...
So, I understand the original spekrum system had a few 'little' problems. Static generation, poor antenna fixing in the module and not sure of any others.
Does the Pro take care of these problems?
Was there a version 2 which had taken care of this a while ago? Before the pro?
I see the pro is waterproof and fuelproof. Is this right?
I also heard that if you run the Spektrum system you nead to use a voltage regulator if you are going to use Digital servos. Is this still so? Or was it only for the previous versions?
Well, I'm thinking of getting the Pro with the R3500 RX receiver as I had some bad experiences at a big race not too long ago so any help you guys can give would be great.
Thanks in advance.
British Menace is offline   Reply With Quote
Old 06-11-2006, 10:54 AM   #2
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Check this thread out , read the last post as well....for the advertisement straight from Spektrum.
Artificial-I is offline   Reply With Quote
Sanwa M11 + Spektrum Pro + Speedmind Bag + Stock Module An6e1o_414 R/C Items: For Sale/Trade 2 10-28-2007 08:00 AM
SEO by vBSEO 3.5.0
