OS Speed
#107
I have used yesterday at Turkish nationals an os.speed TZ with mugen 2501 pipe. My car is a new S-720. When I first use the car, I found the second speed ended to early and place the tallest 2nd gear ratio(23T pinion, 55T spur). But this engine is unbelivable it can easly crank this speed too. This the fastest engine I have ever seen.
#108
#109
Location: Cebu City, Philippines and Ocala, Florida, USA
finally got the let the engine rip out and show it's maximum capability. this engine has tons of torque and has very decent top end speed
#110
Trader Rating: 9 (91%+)
Originally Posted by asil
Yes, I've seen his car at top speed at the middle of the straight with the longest 2nd speed ratio!!! This engine is incredible and in my shopping chart No spares for the crank, piston-sleeve
There was a mistake in printing. In Japan market the booklet shouldn’t have the part numbers for piston, liner, head, and crankshaft.
O.S. in Japan prefer all owner in Japan to send their’s engine back to O.S. Factory for service.
For export engine part numbers should be in the manual booklet but there are none.
O.S. will re-print new manual booklet for export only with all missing part numbers.
There are the part numbers.
Crankcase – 21531100
Crankshaft – 21532100
Piston & Liner – 21533100
Heat Sink – 21534020
Carburetor Assembly – 21538020
Carburetor parts (Needle Assembly – 21538510), (Reducer 5.5mm red – 71533155)
Regards,
#111
Trader Rating: 23 (96%+)
hi all,
can i know what tuned pipe were you using to get full potential out of the OS speed engine???
i was told to use novarossi efra2630 on my os tz 3p, should i use the same pipe on the os speed?
#112
how long has it been since you ran?
i also will be doing break-in of my os 12tz -3p (not an osspeed ), just waiting for my conrod. i switched to 3-port (piston n sleeve0 since my 5-port died on me - my fault anyways...
i just can't believe it, for a month now, i haven't been able to find a single conrod for sale in all of the lhs near me. even the district distributor - out of stock. their selling it like hotcakes here, and they won't have stocks till next month...
#113
I have used both the OSSpeed 1040 inline pipe and the Novarossi 2630 inlipe pipe with 6 fins on my OSSpeed TZ 3P engine. Based on my runs, I find that the OSSpeed pipe gave the engine it's full potential... If you use the Novarossi 2630 pipe and header, you should install a thicker rear exhaust gasket since the Novarossi header has a bigger exhaust diamter compared to the OSSpeed header... Hope this helps...
#114
doki!!! good to know your back running again !!!!
#115
#116
by the way i am not using OSspeed, just a normal OS tz 3p, i wonder would a Os tuned pipe help like the 1040 pipe improve the OsTz3p speed?
os pipe gave Os engine full potential? i might try Os pipe after all,
Well did you feel any different between the nova pipe and the os pipe, cos i just spend money to buy the nova pipe...
i wonder is os speed spec 2 engine is as easy to tuned as OStz?
#117
yeap, i get what you meant, OS have a smaller exchaust outlet,
As for easy tunability, I would say OS engines would be easy to tune... That is one of their trademarks along with reliability... Just my 2 cents...
