V-one S - Max - 12TZ - T3
Hello everyone, i am quite new to the engine concept, i have never upgraded my engine to a .12
I currently have a kyosho V-one S. And lately i have not modiflied it very much. So far i have a different engine which is a O.S. .15 CV Hyper w/10A Slide-Valve Carb but i am looking to make my V-one S a lot more faster. So far the .15 Cv Hyper runs smoothy with my V-one S, Everything on my V-one S is strandard except for the wheels, suspentions and the Engine and it has 2 gears transmission. And than everything is pretty much stock, but i have two questions http://www2.towerhobbies.com/cgi-bin...?&I=LXPV46&P=0 = ( Current motor ) http://www2.towerhobbies.com/cgi-bin...?&I=LXLNF7&P=7 = ( Engine i want to buy) I am looking to improving my V-one S. And i am looking to Buy the Max - 12TZ - T3 which is certain a lot more powerful than the OS .15 CV hyper, and i am wondering if my V-one S will be able to handle it and fiting it without breaking down? The big question is, on the current motor i have the crankshaft is standard, but on the 12TZ it is a pilot crankshaft. It is a lot longer, does this mean i have to buy a new flywheel and do some changes with putting on my 2 gears transmission back on ? Or will everything be easy, just stick on the flywheel, 2 gears transmission so on... Anyone with exprience, it would be great with advice Thanks. I really want a new engine ! ! ! Tom |
TZ is also available in normal shaft, direct fit on your car.
BUT, the 3 ports is straight out of the box, 1.5HP ! This will be very hard on the standaard clutch ! Be aware that you also need other exhaust and manifold, 1040 is great for this engine. And off course... it doesn't come with a pull start ! Will the car handle the power ? Hard to say.. it's a little much for the rubber tyres, drivetrain etc.. engine does 40.000 rpm ! I would upgrade to v-one RRR WC or FW-05RR, and even those need some adjustments to handle the power ! (Steel versions of gears etc) But nice choice of engine ! |
