Old 05-22-2006, 05:24 PM   #1
Pain's Avatar
Send a message via MSN to Pain
Default Do I have to cut the crank?
Hi I just bought a Novarossi for my Kyosho GT Inferno. The crankshaft is to long for my flywheel and 2 speed set up i have. If i cut the end of the shaft off it will work. But my question is. Is there another way to make this work with out cutting it off? Question # 2.... The flywheel the kyosho came with is way to big around. Is there a different one i can use for this engine. It worked fine with the stock engine, but with this Novarossi the flywheel hangs down below the chassis. I tried a regular flywheel but it will not work with the 2 speed. Thanks for any help you can give me.
Pain is offline   Reply With Quote
Old 05-22-2006, 10:03 PM   #2
soc123_au's Avatar
R/C Tech Charter Subscriber
You will need a different flywheel, kyosho makes different offset flywheels. your best bet is your local hobby shop. I had this problem about 4 years ago & I took the lot down to the shop & we found the flywheel that worked. I dont remember the part number. Try posting in the offroad section you are more likely to find someone else that has been in the same jam as you, only a bit more recently than me.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Standard crank shaft to SG crank shaft adapter? Fred Perkins Onroad Nitro Engine Zone 5 04-02-2007 10:53 PM
P5 crank tao3 Australia Wanted to Buy 0 01-14-2007 12:50 AM
Can you make a std crank engine a short crank engine? jamiekulhanek Onroad Nitro Engine Zone 3 09-18-2004 10:47 AM
NEED: M12 crank..... racer_RR R/C Items: Wanted to Buy 0 08-27-2004 09:36 PM
V-one S + Sg crank au_Nightmare Nitro On-Road 3 08-07-2003 11:04 PM
SEO by vBSEO 3.5.0
