Mugen MRX-4R
#721
Does anyone know of a good way to clean the baked on tire foam and oil crud from your exhaust???
#724
Put it in a crockpot with regular antifreeze (not dexcool) and cook it for a couple of hours, it will rinse right off with minimal scrubbing.
#725
Fuel consumption
Hi there!
Could someone please tell me what options I have to make 5 mins. between stops with a Nova 35+21?
If I need 20 or 30 sec. more what can I do? Which manifold which restrictor?
Many thanks in advance guys!
#726
Originally Posted by fulcrum2
Hi there!
there are several options what manifold, restrictor and exhaust pipe are you using now?
#727
Hi there!
Before the Ninja, I was running 35+21's and I resolved
the fuel issue by running an INS Box & the JP 3 Chamber
pipe. I ran the Medium Conical Header as well.
Take care!
Terry
#728
Originally Posted by T-BODZ Terry B.
Fulcrum2,
Take care!
Terry
Take care!
Terry
Has anyone measeured their fuel tank's capacity? Art Carbonell mentioned to me the other day that most MRX4R's tanks are quite a bit undersized. Is this true? I have yet to measure mine-just curious.
#729
A-RASSS
I'm using Nova 2052 pipe and have all three conical manifolds 41015 16 and 17.
Should I work with different air restrictors?
Many thanks for lookin' into this!
#731
#733
A-RASSS
If youre racing a mrx4 check the tank capacity most of them are too small even 120 cm3 You can open them a bit with a hot curved metal surface from the inside to the outside.
If you still get out of fuel in a heat think in getting a semi conycal header or a conventional header but that woul reduce the overall performance considerably.
You can also alter the gearing, latest tendences is that with shorter gearing the mileage is increase although it would seem the opposite.
Also a too loose clutch setting increases a lot the fuel consumption, check that also.
best regards and good races!
#734
Thanks for the advice A-RASSS!
I just found an old 2006 Nova pipe. Should it also give lower consumption? Too cold to try it at the time being...
