Mugen MRX-4R
#31
Originally Posted by Joe Os
I upgrade some major parts like this:
#32
Originally Posted by Mugen4lyf
Wow. How much did you buy that kool staff and where?
http://www.brooklynhobbies.com/index...TS&Category=47
Mugen website and some hobby store...
#33
Originally Posted by Corse-R
That first pic (the one with the main shaft) shows a big problem... galling just in the place where the rear pulley and brake disk holder goes (was tough to remove the piece?).
Before installing, put a little of grease just to prevent galling in the future. Watch out the bearings, seems that score the main shaft.
I see a bunch of Ti parts out there. (Dogbones and main shaft... expensive, quite expensive). The Carlsen front outdrives are nice, but their machining quality, leaves a little to desire (seen a set of those and the machining wasn't as nice should be leaving sharp edges).
I prefeer a set of hollow steel main and front shafts (cheaper). Seems that Carlsen has some of those.
#34
Everything? hmmm i spend more than a cost of .12 mod JP engine
#35
Hello guys whats the advantage and disadvantage bet. the MRX4 & MRX4R?
#36
#37
The '4-R' is the MRX4 with some different parts used at the past worlds at Messina (you maybe heard about Messina kit). Those parts range from the most subtle different (front a-arms) to the rear shocks and the new shock stay, rear a-arms, bulkheads, belt tensioners and other parts.
#38
what about the rear shock? long and short whats the defference? pls.
Look at this page and you'll see how was the MRX-4. The third photo shows the rear shocks. Compare them with the 4-R.
http://www.mugenracing.com/mrx-4.htm
#39
mugen
the new rear shock bodies are longer than the original, i know this cause i have both kits.
i believe they were made this way to accomodate the new rear shock tower as well.
its nice cause now you dont have to compress the spring by bringing the collar 3/4 of the way down the shock body.
the new "R" kit kicks ass.
i am very new to the racing scene, and still learning everytime i get out, but i have talked to many drivers which have switched from serpent or kyosho and said the mugen is a dream to drive......
i call it a rush!
i have also noticed that the changes made in the "R" kit are very minor, which is a good thing, it has been a solid car right from the start, so why change.
one thing, i would like to see however, is more aluminum, standard or option.
keep up the good work mugen seiki.
forever a customer.
steve.
i call it a rush!
forever a customer.
steve.
#40
i call it a rush!
forever a customer.
steve.
i call it a rush!
forever a customer.
steve.
#41
i call it a rush!
forever a customer.
steve.
i call it a rush!
forever a customer.
steve.
#42
It seems like they pretty much the same. i dont see at all?
#43
Anyone try the 15t 1st gear from kyosho or serpent to MRX4R?
#44
mrx4
i think that would be too small, i tend to race on larger tracks where taller gearing is needed. but then again, maybe i should try it out.my club is in hamilton, ontario, but i try to make it to cincy or toledo whenever i can.
usually i am running the 17,20 tooth combo
#45
mrx4
mad-killah, if you look closely, you will notice that the new ones(MRX4R) are longer.
