Old 01-02-2003, 06:37 PM   #1
Hpi Rs4 3 Engine
I am putting a .15ss in place of my .15fe on my rs4 3.
My goal is to beat a stock traxxas 4-tec on parking lot draging.
Should this be all i need to do or will i need to change alot more on my car?
DEONE469 is offline   Reply With Quote
Old 01-02-2003, 08:35 PM   #2
popsracer's Avatar
Default .15ss in place of my .15fe on
If your talking about the Nitro 4-tec, then you may also need a 2 spd transmission on your car to level the playing field. Get the 13/18 clutchbell and matching spur gears and set the tranny to shift early after about 15' out. Should be enough to beat the Traxxas.
Good luck racing
popsracer is offline   Reply With Quote
Old 01-04-2003, 05:21 PM   #3
If you can change to a slide carburetor you will get much faster off the line acceleration as the air intake is a little bigger and the air flow is guided straight into the engine rather then around a bend as in the rotary valve type. He won't be able to keep up from the start.
speedoo is offline   Reply With Quote
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 03:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
