Exhaust hole.
Old 05-11-2006, 03:43 AM
Default Exhaust hole.
Would anyone be able to tell me what they use to help prevent body being burnt at the exhaust? Is there any kind of protection for it? Its actually happened that its made the hole in the shell a lot bigger...and i dont want to get failed in scrutineering obviously..
Thanks.
Ian C is offline
Old 05-11-2006, 04:01 AM
you could use some 1/4inch fuel tubing (from lhs), push fit over the stinger and cut to length so it exit outside the body.
MisterLister is offline
Old 05-11-2006, 09:39 PM
ProudSavageOwnr's Avatar
if ur burniing a big hole inthe side of ur body get some alloy foil tape from a hardware store and put a few strips against the body but if ur talkin bout wer the stinger exits the body just make the hole abit bigger and cut some fuel tubing in half and glue it around the hole.....
ProudSavageOwnr is offline
