Old 05-07-2006, 12:17 PM   #1
hi, i got my engine started on mc nitro car and the electrics worked fine while starting, when i gave it some throttle it sped off and wouldn't brake, it hit a kerb and stopped, i turned off the engine. the radio gear wont work now,
i have tried changing all the batteries
disconected the fail safe
reconnected the fail safe
The handset does not have any effect on the radio gear in the car, the engine still starts though, the handset shows full battery and the receiver is switched on. (it a ACOMMS)
i am a beginner and so help would be greatly appreciated,
khany1 is offline   Reply With Quote
Old 05-07-2006, 12:53 PM   #2
Car Breaker's Avatar
have you set the failsafe right, it has to set to pull the break when lost signal, else failsafe is meaningless
Xray X12 2015
Car Breaker is offline   Reply With Quote
Old 05-07-2006, 01:15 PM   #3
TRFTIM's Avatar
Disconnect the failsafe and try again.
Check the crystal isnt damaged by either changing it or trying it in a different receiver.
Check the ariel hasnt been pulled out of its housing.
TRFTIM is offline   Reply With Quote
Old 05-07-2006, 02:42 PM   #4
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Ok so did the TX aka transmitter aka remote in your hand. Work at any time? You said you hit throttle and thats all it did and now it wont work?
Make sure your battery isnt getting disconnected. If you have AA's in a plastic box , then that could be one problem. Get some eletrical tape and wrap the battery box so they wont come loose.
Next swap one thing or try one thing at a time.
DO NOT RUN YOUR CAR AGAIN ON THE GROUND. Leave it off the ground and do not turn it on until you can see that its responding to your input.
Then start the car and try playing with it again "OFF GROUND" , if you loose control again. Goto the car and return the carb to closed position and then shut it off.
If all is well then run it , if not.
Youll need to call your radio kits company to see if they can offer some help , also try taking it to your local hobby shop. There can sometimes be so many things its overwhelming for someone new.
Good luck.
Artificial-I is offline   Reply With Quote
Pinions, Radio Gear and Battery Gear d4_racer Australia For Sale/Trade 9 09-18-2007 01:07 AM
Tamiya Mini 4WD gear problems flash1986 Micro and Mini Scales 1 07-18-2007 05:42 AM
1st gear one-way problems deceiver Nitro On-Road 1 07-07-2007 02:33 PM
Radio Gear problems NITRONUTTER Australian Racing 6 04-11-2006 04:17 AM
SAVAGE SPUR GEAR PROBLEMS Rookie 4.6 Monster Trucks 12 01-15-2006 02:02 PM
SEO by vBSEO 3.5.0
