Old 05-04-2006, 12:43 PM   #1
Default LUBE -OIL AND ????
when maintaining a gas sedan, what all do you service and what products do you like for these critical areas? lets here it thanks...
impdog is offline   Reply With Quote
Old 05-04-2006, 01:11 PM   #2
Corse-R's Avatar
The best for taking care of your car when servicing it are the Serpent oils (all two: One-way and Bearing oils).
You can use too some brake cleaner just to remove the grime (nothing beats to a full dismantle and a throrough clean - Serpent cleaning putty is the best you can find it too. Nothing more and nothing less (and of course, a set of high quality keys and screwdrivers to not marr your screw set).
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-04-2006, 08:44 PM   #3
i like the GQ air filters as there cheap and last a long time(when you look after them properly)
and you can't beat sirio plugs. They last a long time and engine fires up straight away no probs
ae_ntc3 is offline   Reply With Quote
Old 05-04-2006, 10:48 PM   #4
performula's Avatar
Check your shocks before each race weekend, hit the set-up, denatured alcohol and spray bottle for cleaning, make sure everything is charged, spares, fuel, tires. The best product you could buy is denatured alcohol for sure.
performula is offline   Reply With Quote
to lube...or not to lube! builthatch Electric Off-Road 7 11-11-2006 08:39 AM
Lube Jez81 Rookie Zone 14 05-19-2006 06:25 PM
New Diff Lube CellBoy77 Electric On-Road 42 10-27-2005 10:29 AM
New Diff Lube CellBoy77 Nitro On-Road 0 10-24-2005 11:23 AM
Bushing Lube RadioRogue Electric On-Road 7 02-19-2002 01:48 PM
SEO by vBSEO 3.5.0
