Starter Boxes
I have the Duratrax Universal w/ Power Panel and love the thing. Has a glow igniter that hooks into it, check power by the push of a button. It's heavy but has the power. Alot of bang for you buck.
Here it is:
http://www2.towerhobbies.com/cgi-bin...&I=LXHAR1&P=ML
Add a body, can of paint, and save $10.00.
Here it is:
Originally Posted by PhatPat
Thanks, Looks good. Do the twin 540's pack the punch for breaking in new engines?
I like my AE NTC3 starter box, or you can get the OFNA one with a on/off swtich and gel cell battery mount for the same price, they are almost identical, but it can fit in a 12V gel cell battery within and use 1 750 motor.
About $70 plus $25 for a gel cell....Tower has it. and Albert can order one for you as well with discount
Single motors aren't more powerful than dual motors - they just have a little more RPM. What you need is torque and the 12v batt provides 7amps to give those motors some power. TWo stick packs won't do the job as good as the 12v. I've run my Ofna black true start 10th scale box on 1/10th nitro on/off, and 1/8th on/off with no hassle what so ever. I've seen many single motor boxes have a hard time cranking really tight motors. Another bad thing with those singles, what happens when they die on the track? Two inexpensive 19T motors are great replacements for the box. A pair of hot modified motors won't do the truck as they don't have the low end grunt.
i have always used the ae starter box because it has the torque and also it has 3 different mounting positions so if you ever change cars you don't need to buy a new box. i just put 2 3000mah stick packs in there and away you go!!!
Originally Posted by HarKonnenD
Single motors aren't more powerful than dual motors - they just have a little more RPM. grunt.
I disagree. The only thing worse than one weak suck motor is two weak suck motors and the 540 motors for starter box application are pretty weak suck in the torque dept. Do yourself a favor get a box that has a 700 series motor. They have the beans to get the job done. I am currently using the new GS box. Very light, easy to mount a sealed lead battery, and replacement parts are available for it.
I just got a mugen starter box, and compaired to the Ofna, AE and some other piece of $h!# I had, I like it the best. Its light, powerful and small. Only complaint is that building it was a pain.
I have the 1/10th box and have no issue whatsoever starting all sorts of engine. I just loosen the plug before starting which makes. I have no issue about my box being heavy...it's mainly the battery, but with muscle I don't complain about that weight.
