Kyosho V-ONE RRR Evo
#526
Originally Posted by ITO NIEVES
Where i find the solid axel Tosolini and Shimo uses in worlds?
#529
Originally Posted by kewdawg
What does it look like? Any pics?
#531
Location: Cebu City, Philippines and Ocala, Florida, USA
nice...hope kyosho will release it soon or maybe what they can do is make a one/solid axle type design somewhat similar to the one that's on the g4s. it makes it a lot easier to switch between oneway and solid axle buy just adding 2 pins and securing it with o-orings
#535
The spool is hardened steel, just like the outdrives - we also had some new driveshafts ( front ) which are silver in color , they are slightly longer and also have longer drive pins which protrude past the edge of the outdrive cup.
The engine is in fact an EVO3 STI, they used the Evo2 head due to the hotter weather , apparently lowers the temp by about 25 deg.]
If you guys have any more questions fire away, I was there!
#537
The engine is in fact an EVO2 STI, they used the Evo2 head due to the hotter weather , apparently lowers the temp by about 25 deg.]
I assume that you mean it's an EVO3 STI with an EVO2 head?
#538
forgot where i downloaded these images from...they were named toso.jpeg and shimo.jpeg respectively...car posted earlier looks like toso's...but i could be wrong...
#539
#540
Was that car scratch built or an r&d car from Kyosho?
Who's car is that? It looks like it has an EVO 2-speed shaft with a Mugen or Serpent gear on the end.
