Kyosho V-ONE RRR Evo
#3198
Won't wear at all! Very little wear with diff! Cap clutch everything is smaller/lighter...... Quicker spool up more snap. It will b the difference of ur car feeling heavy on track, or really light n quick.....The shimo clutch is prob close to same performance as cap.....
#3200
#3201
As far as motor less than $300. Stick with novarossi. U may find a "keep on" "Rb T11" "3sct" "353" Look on Amain an absolute hobbyz. Good prices there
#3202
Yeah you'll never get a 3d kyosho clutch to come out of the corners strong......I tried for years
#3204
#3207
I have a few questions about the CVD"s
Looks like I have 50mm black in back, 47mm silver in front works good with spool or oneway. And I have a set of 45mm black ones, only thing I can think is the 45mm ones work with the front diff? It seems its about 1mm longer?
And I see theres 52mm you can get for the back. Is this to get the width to 200mm? Seems like mine now is 197ish. And the front is 200. If yes what do u do install the 52mm and screw the pivot balls out and lengthen the upper link?
#3208
#3209
HTH
