Kyosho V-ONE RRR Evo
#2881
Also, I use them for tuning a small bit. I have gone back to the steel pinions with the IDM engines to try and calm them down a bit.
#2882
#2883
I have both aluminum and steel pinions. Practice and run club races with steel and for races that are more important, I run the aluminum.
#2884
just ran my car for the first time last weekend at RCCAR in san jose and it was awesome! I finished in second behind teammate Jimmy Deprez, but got fastest lap!!!
anyways, I had a couple of questions for you guys..
where can i buy a good titanium screw set for this car?
And do they have a titanium or hollowed steel drive shafts for the car?
any help would be greatly appreciated!
steve
steve
That set do not have only the 2.6mm screws for the diffs and battery plate.
#2887
That's what I thought, but I'm having a hard time finding a part number for it. Can you give any advice where to find the part number? Thanks.
#2888
The easiest way to picture all this is go to the Kyosho America website and download the manual for the RRR WC edition (not the EVO WC). It uses the older pulley and brake cam. It will show you how it goes together and the back of the manual will show the exploded view as well as the parts listing.
Pulley set VZ203.
#2889
Aaaaaaa, OK, That's what I used to run, but I switched to the EVO system when my brake cam wore out.
#2890
Hello looking for some clutch setup advice. I recently switched from the mugen to the Kyosho car. Very happy with the switch. Looking to get gapping, spring recommendations etc. I run on a mid size track with medium traction and some fairly tight corners. Also what is the feedback on the new clutch system aftermarket.
Thanks for you help,
Brad
Brad
#2891
Are most people running the aluminum or steel pinions? Mine seem to be really sharp after only 3 racedays..
#2894
Brad
Brad
most common gap ranges 5-6
med traction .60-1.2 spring tension kyosho hard spring or orion spring
barely any endplay
#2895
Could someone post or direct me to a gear ratio setup sheet? I'm looking for something that gives me the combination of the spur and pinion and what ratio it gives me. Thanks.
