Kyosho V-ONE RRR Evo
#2687
I dont know if everyone does this, but I leave the play in there. My main shaft and the middle shaft also have somewhat of a play. I do this so that the whole transmission runs smoothly and that if I a belt is positioned wrong by a small length, those degrees of freedom will let it run as it should. That is my own understanding.
#2688
RRR outdrive PLAY
I just finished putting together a RRR evo WC.......and I had the same problem with play in a few of the outdrives.......and I also shimmed them to remove this play as I had always done with other kits.......until someone who has more knowledge than I with the k-CAR pointed out tht there are 2 ways to put on the BLUE HEX DRIVES....on the flat side of the hex or the pointed side of the hex.....take ur wheel of and look at it!!!!ur gonna say ooohhhhhh...I missed it in the instruction manual to!!.....depending on which hole u choose 1 will cause play and the other will take it away!!!!no need for shims at all...used 8 shims in my G4..4 shims in my NT1..Both good cars ..but I think Kyosho has got this thing figured out!!....this is actually the 1st kit tht I hav built wit almost no slop anywhere!!!very impressed
No I didnt glue my o rings in......I could see why they would want u to.....has some side to side play there and before u sandwich the 2 halves they could prob come out.....but It seemed to me tht once u put them together they shold stay in place!!I havent ran car yet,,but I hav seen no signs of leaking!!
#2689
Alright guys...
I'm a long time Electric touring car racer and I've been thinking about getting into nitro touring cars. A few of my good racing buddies run the Kyosho car, and I figured it would be a good starting point to get into nitro touring car racing.
But, I just wanted to know if there are any must have hop ups for the evo WCE. We'll be running on a medium bite parking lot track Thanks for the help guys!
-Korey
P.S. If Mike Ellis is reading... I'm TOTALLY serious about getting a nitro touring car! hahaha
-Korey
It is Good to see you coming out your new Nitro burner...
btw I think Mike Ellis running the NT1 this year...
#2690
Hey Guys,
im looking for a english pdf setup sheet for the RRRevo that is editable so i can e-mail it to a mate.
thanks,
Chris
thanks,
Chris
#2691
Did you try the kyosho usa site ?
#2692
yep but i cant find an editable one
#2693
So the Pre-worlds winner is the V-One. Does anybody know what engine Daniele Ielasi was using? It was a CRF or a Sirio?
#2696
Yes you should, but kyosho thrust bearings are one of the best in the market, you probably won't have problems with that and should last a long time you take good care of them.
#2697
thanks.... its just that when i pulled it apart it was dry (i got the car second hand)
also is it posible to fit an os tg motor in this car, one with a pullstart.
and will the slide carb & rotary carb versions both fit also??
#2698
I beleive it's possible if you use the V-One S parts, but in the original RRR parts probably will not fit.
V-One S3 uses GRX15 engine, that has a side exhaust and a pull start.
#2700
Tony, you should be using the 60 or 61 first gear spur, on second gear I tried the 55 and the 56, the 56 is better, the 55 wont let the engine reach top RPMs at CP, the straight is not long enough. THe 55 works good the GLARC track, with the longer straight. As far as pinions, I dont know the tooth count, but Im using the blue first gear and the black second.
