Kyosho V-ONE RRR Ultimate Edition (UE)
#47
Originally Posted by robert maestrey
Nice comment........We all know that the Mtx4 is a very good car ......the only problem is this is a RRR thread to help people.....So your comment is a little out of place ......Take care have a nice day
#48
Originally Posted by GrandeGixxer
Some can't take a joke. I am actually thinking of switching over next year to Kyosho.
Why put off until tomorrow, what you should have done the day before yesterday?
Cheers!
#50
Money issues, I already have the -4 and a bunch of spare parts. Next year when taxes come in I will probably get the RRR or whatever is out then. Don't get me wrong, I do like the Mugen a lot, but I am open to other options.
#51
Originally Posted by rmdhawaii
Since we're just joking around, then this should look familiar:
Cheers!
Cheers!
#52
I know a way to make your project a whole lot easier, just throw an MTX-4 in the box!
It just shows that everybody is interested in what we are doing.
#53
Here's one you won't find in any catalog:
Brand: Kyosho
Part number: VSW043
Description: 3D Lightweight Flywheel
Type of upgrade: Performance
Reason: Lighter weight in the rotating assembly
Setting: N/A
This upgrade is actually listed for the FW-05R but it is exactly the same size as the flywheel for the RRR. We checked with Kyosho America and they said it would work and I am using it on my car now it is perfect. It even has 3 notches in the back that you can put a wrench on to hold the flywheel.
Brand: Kyosho
Part number: VSW043
Setting: N/A
#54
Originally Posted by litespeed-dom
Here is what Kyosho consider as Optional parts, of course certain ones come with the WC kit already. I'm not posting this because I feel all these parts are mandatory, but just an FYI for those want to know what is being offered by Kyosho. And I can't guarrantee availability of these items either.
Dom
92702B SC SPRING
APP02-2 APP BRAKE PAD (FOR V-ONE)
BRG022 SHIELD BEARING (6X10X3)2PCS
FM337 9MM BALL SCREW
FMW11 CLUTCH SHOE (RED)
FMW16 CLUTCH SPRING (H)
SPW5 ADJUST ROD SET L=15,20
VSW003 ALUMINIUM ENGINE MOUNT
VSW007 UNIVERSAL SWING SHAFT (SHORT)
VZ113-59 1ST SPUR GEAR (0.8M/59T)
VZ113-60 1ST SPUR GEAR (0.8M/60T)
VZ114-55 2ND SPUR GEAR (0.8M/55T)
VZ115-20 1ST GEAR (0.8M/20T)
VZ115-22 1ST GEAR (0.8M/22T)
VZ115-23 1ST GEAR (0.8M/23T)
VZ201-1 FRONT KNUCKLE ARM (KINGPIN ANGLE 1DEG)
VZ201-2 FRONT KNUCKLE ARM (KINGPIN ANGLE 2DEG)
VZ237 DRIVE BELT 387 (RRR/FOR 24T PULLEY)
VZW009 TCD GEAR SET
VZW010 DRIVE WASHER
VZW010-1 O RING SHAFT SET
VZW024V 64 TI/9MM BALL SCREW
VZW024V-8 64 TI/9MM BALL SCREW 8PCS
VZW052 CARBON FRONT SHOCK STAY
VZW054 UNIVERSAL SWING SHAFT
VZW054-01 SWING SHAFT(FOR UNIVERSAL/45MM)
VZW054-02 WHEEL SHAFT
VZW054-03 JOINT BLOCK SET
VZW063 ALUMINUM BRAKE LEVER(RRR/BLUE)
VZW064 LIGHTWEIGHT 1ST GEAR HOUSING
VZW065 ONE PIECE ENGINE MOUNT
VZW201 SP DRIVE BELT 189 (RRR) FRONT
VZW202 SP DRIVE BELT 384 (RRR) MIDDLE
VZW203 SP DRIVE BELT 180 (RRR) REAR
VZW205 ALUMINUM BRALE HUB (FOR RRR)
VZW206-18 ALUMINUM PULLEY (RRR/18T/1PC)
VZW206-21 ALUMINUM PULLEY (RRR/21T/1PC)
VZW206-23 ALUMINIUM PULLEY (RRR/23T/1PC)
VZW206-24 ALUMINUM PULLEY (RRR/24T/1PC)
VZW206-27 ALUMINUM PULLEY (RRR/27T/1PC)
VZW208 FRP BATTERY PLATE (V-ONE RRR)
VZW209 64 TITANIUM SPUR GEAR SHAFT (RRR)
VZW211 64 TITANIUM BEVEL SHAFT (RRR/FW)
VZW212 FRP MIDDLE PLATE (V-ONE RRR)
VZW213 LIGHTWEIGHT CLUTCH BELL (RRR)
VZW214 SP MAIN CHASSIS (RRR/7075/3T/GUNMETAL)
VZW215-15 1ST STEEL GEAR (0.8M/15T) (FOR RRR)
VZW215-16 1ST STEEL GEAR (0.8M/16T) (FOR RRR)
VZW215-17 1ST STEEL GEAR (0.8M/17T) (FOR RRR)
VZW216 ALUMINUM MIDDLE SHAFT MOUNT
W5105BK SHOCK CAP SET (BLACK)
W5105G SHOCK CAP (GOLD)
W6001 TITANIUM COATING SHOCK SHAFT
W6002 TI COATING SHOCK SHAFT (30)NUT
W6007 HC DIAPHRAGM (WHITE)8PCS
Dom
92702B SC SPRING
VZW009 TCD GEAR SET
VZW010 DRIVE WASHER
#55
Dom
92702B SC SPRING
VZW009 TCD GEAR SET
VZW010 DRIVE WASHER
Dom
92702B SC SPRING
VZW009 TCD GEAR SET
VZW010 DRIVE WASHER
great Job dude
#56
What are we going to do about the rear shock stay? Please choose one of the following:
1. Kyosho VZ231B (standard WCE)
2. Kyosho VZW207 (new) - http://www.rctech.net/forum/attachme...hmentid=129143
- http://item.rakuten.co.jp/rc-rainbow/4955439870976/
3. Skyline Racing Development - SKL-5002 (4mm) - http://www.skylinercracing.com/store/P_39.htm
4. K Factory Racing K1907 (4mm) - http://www.kfactoryracing.com/produc...1907&pageNum=3
#57
SHOCK
i have the vzw207 wasnt able to try it out this weekend will try it & give a report
#58
#59
p/s: Mark, can u give us a brief review on this product? Thanks in advance!
