Thrust Bearing Question Please
I have a Centax Clutch and have broken nthe thrust bearing on it part number 1377, is there an alternative to this part or will I have to find the part from somewhere?
I believe it is 5x10
you can use a normal bearing thats the same size.
Wiht the centax Clutch you need to use the Trust bearing again , if not the screw will become loose and have clutch problems.
i dont see how it will make the screw come loose ive had a mtx3 clutch like this for 5 months now and havent had a problem
the only way the screw will come loose is if you dont tighten it properly
One of the functions of the trust bearing is that "Trust" , If you have your clucth gap properly set. The trust bearing will prevent that when the clucht hit the bell it doesn't turn the screw. It will make the bell spin easier No mater the pressure the shoes applys to the bell.
Just more simple, just look how the balls are resting on the trust bearing and how they are set on a regular bearing. In wich direction they roll???
Do I have to take a F***en picture of what ive done, it works fine
oh and by the way I do know how to set up a clutch
Yep you have to replace it with a thrust bearing as the outward load of the centax lands squarely on the balls of the thrust bearing regular bearings have the balls lining around the shaft while the thrust's balls face the clutch it self. It isn't at all the same as a regular bearing.
on a normal bearing the force is placed on the balls going away from center
on a thrust bearing the froces are pushing on the face of the bearing.
constant cleaning and relubrication is required on thrust bearings as well as setting the proper gap between the bell and the shoes.
What car is it in?
What car is it in?
i know what a thrust bearing is and how it works, if the guy keeps blowing them he can put a normal bearing or a bush in there ive had my mates mtx3 clutch like that for 5 months and havent touched it since i put in in
Obviously you have some rage issues as my post was intended for the original poster TRFTIM. I was just trying to educate him. I'm sure that the regular bearing works for you just fine but I think he would be better off replacing it with a thrust bearing as the manufacturer intended.
there was no rage intended in my 3rd post
Also you tried this because you probably wondered why you yourself broke this thrust bearing, no wonder if you never touch, clean or check your clutch for at least 5 months......
[QUOTE=subman constant cleaning and relubrication is required on thrust bearings as well as setting the proper gap between the bell and the shoes. [/QUOTE]
It isn't the gap which is important.
Setting the endplay as minimum as possible, that is important......
Thanks for the replies Guys most helpful but dont fight between yourselves now we are all equal in this hobby
The car is a Serpent 705 not to sure if it is the Centax 2 or 3 clutch, how do i tell??
I have seen some ceramic thrust bearings for a Centax 3, but not to sure if they will work with my one, my one has a Yellow friction dome??
Thanks again guys great stuff.
It also tells you how to set it up properly.....
http://www.mytsn.com/publ/publ.asp?pid=10534
