Serpent 720
#4712
Hey guys after leaving nitro and going electric (not the greatest decision) I decided to go back to nitro and i am really considering getting the 720 09 kit but i was wondering what is the brass plate and what does it do and do i need it? Also what parts break on it the most that i would have to order enough of because no one around here supports serpent except for the fact i am only three hours away from ashford hobbies. Thanks in advance
#4713
Oh and i guess i should have added that i plan on racing at two tracks one that is a bowl (mushroombowl.com) that has about medium traction but has some bumps and the other track (bluediamondpark.com) is a flat track and it was moved away from the offroad track so it doesn't have to be constantly cleaned and so far what i heard is that it is like tennis court asphalt and looks like glass and i was told traction is going to be ridiculous.
#4714
#4715
Hey beta bob, the brass plate is used for two reasons 1) it adds weight 2)when installed it makes the front end stiffer. Robert at ashford will have what u need and any info u need, also kamikaze is just as helpful and will also have parts. Very good car. Lots of support when u need it here.
#4716
-Front Racepack
-Rear Racepack
-Set of belts
-Extra set of spurs
With this you should really be alright. I have yet to strip a spur. Belts last alot of runtime if taken like they should (keep the pulleys clean). Since I bought this car, I have yet to break a pulley on the diff, spool or either internal pulley.
I have never broken a front/rear shock tower, and the updated rear end is much much stronger so youll break the rear arm before this.
If you do crash alot and you anticipate your crashes will be catastrophic, just then I would suggest to carry an extra set of CVDs.
Hope this helps.
#4717
Thanks for the help guys but what is a front and rear race pack? Is that bulkheads?
#4718
torque is how many parts you have to replace afterwards !
#4721
#4722
Hey man, you should have dropped the tank in so we could get you rolling! You know where to find us, we got you covered!
#4723
steering
What could I make to improve the steering of my serpent 720???
#4724
