Serpent 720
Old 07-17-2008, 07:22 PM
  #3811
Team Kamikaze's Avatar
Originally Posted by Dpepin
Hi everyone,
I just go an Xceed Rx pack and regulator and I was wondering where you install the regulator on the 720.
Also how long can the pack last, will it last for a day of racing or should I charge it before my main.
Thanks for your help
You can install the regulator in between the fuel tank and the pipe under the radio tray.
If fully charged, the 1100 mAh will run one hour and forty five minutes (continues) in your 720 (based on 2 JR Z9100S digital servos)
Team Kamikaze is offline
Old 07-20-2008, 06:46 AM
  #3812
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Default WC update
hi guys, just wondering if the std transmission on the 720 06 can be updated with the WC clutch bell pinions and spurs, or do the spur housings need to be updated as well, or any clutch parts. thanks.
Pattojnr is offline
Old 07-20-2008, 08:33 AM
  #3813
The tranny is the same, so yes you can.
DJ
dj apolaro is offline
Old 07-20-2008, 08:41 AM
  #3814
Pattojnr's Avatar
DJ
thanks DJ , i have just got the car, so ill see where i can put it here in AU.
i have just come from TM and this is my first change in tourer, i havent driven any other car. so will be interesting. but i was looking at gear ratios, and the WC options are better suited for what i need. so ill try and get them on asap. the rest of the car is fairly std.thanks for the reply
Pattojnr is offline
Old 07-20-2008, 05:59 PM
  #3815
Default Centax III WC
Anyone knows the size or P/N of the small ballberings in the new Centax III WC??
Thank you
Fernando
Fernando_M is offline
Old 07-20-2008, 08:28 PM
  #3816
NitroWD's Avatar
oh no...
hope you're not leaving G4 for good.
why the change?
NitroWD is offline
Old 07-20-2008, 10:52 PM
  #3817
Serpent720's Avatar
Default Belt Position
On my 720, the rear belt keeps riding the edge of the gear. Should I move the small gear a little? If I do, the belt seems to rub the edge of the small gear lip a little.
Serpent720 is offline
Old 07-20-2008, 11:08 PM
  #3818
Hyde's Avatar
do any parts fit the impulse
Hyde is offline
Old 07-21-2008, 12:18 AM
  #3819
Hi Dj,
Can you say me what is the lenght of your shock absorbers ? 67-68-... ?
Regards
Manu_05' is offline
Old 07-21-2008, 02:05 AM
  #3820
Sow&Steady's Avatar
It should not matter but yes, you can move the small gear on the main shaft a little. With some trial and error you should be able to get them aligned.
double check the bearings eccenter holders ... both sides have to be the same.
Sow&Steady is offline
Old 07-21-2008, 02:08 AM
  #3821
Sow&Steady's Avatar
One of the most common mistakes with assembly of the car is that the side pulleys are swapped front-to-rear. Double check these or when you see that the car is slowish when everything else is right on it ... then check these side gears.
Old 07-21-2008, 02:53 AM
  #3822
Pattojnr's Avatar
thanks steady, i will keep one eye on that. the other well who knows
Pattojnr is offline
Old 07-21-2008, 02:55 AM
  #3823
Pattojnr's Avatar
Originally Posted by NitroWD
oh no...
why the change?
there are reasons for change. everyone does it. i have only known the G4 since i have raced tourers. something came up, so i took it. i hope to get my 960 08 shortly also.
Pattojnr is offline
Old 07-21-2008, 07:24 AM
  #3824
Originally Posted by Manu_05'
Hi Dj,
Regards
I am not sure at the momoent. When I build the shocks I just make sure they are long enough that they do not bind and extend with the arm all they way through the droop action. Then I make sure they are equal and have similar rebound. Hope I explained myself OK.
DJ Apolaro
Old 07-21-2008, 10:55 AM
  #3825
fly_wheel's Avatar
by the way, how do u measure the rebuond of the rcc shocks, and how to adjust the rebound? all 4 corners of my shocks have different rebound... i've changed most of the parts, sponge, o-ring, oil... i'm using the stock 3 holes + 35cwt oil front n rear...
fly_wheel is offline
