Serpent 720
#3376
1 degree L/R steering blocks gives u a smoother grip in corners at low - medium traction surfaces whereas 0 degree blocks works better at medium traction sufaces. In general, 1 degree blocks are more versatile coz u can switch the orientation (swap L/R) and gives u better grip at high traction surfaces. 1 degree blocks can be quite aggresive if you are not use to it and requires a little training to get it right. I find the 0 degree blocks easier to drive. Hope this helps...
Cheers,
Raymond Chan
Cheers,
Raymond Chan
#3377
RE: Steering Blocks
Cheers,
Raymond Chan
#3379
hi guys
What is the part number of the flywheel cone for mega zx12 engine? 6503 is the cone for novarossi based engines, but I need a cone for my mega zx12 engine.
thanks and regards
Eduardo
thanks and regards
Eduardo
#3380
Just got my 720 08 kit. The front diff gets 50 000 oil and rear gets 30 000 oil with the kit. My car kept pushing going into the corner so I replaced the 50 000 in the front diff with 30 000 oil.
1)My question is, what happens to the handling of the car if I go even thinner with the front oil? (if I go to thin).
2)What effect will it have when the rear diff oil goes to high or to low?
3)The 08 kit comes with a brass insert in the chassis plate. I know that it adds weight to the front of the car, and therefore creates more down pressure on the front wheels. Will this insert make the car turn in better or push during turn in? What effect will it have on corner exit?
4) I bought the CF insert as well. What will happen to the handling if I use the CF insert? (guess it relates back to question 3)
#3383
Here is my Winternats Set-up!!
#3384
Today I change the same L shape Plastic to Aluminum because the two small holes that I used so I could attach this to the Carbon top plate (803153) crack with the car vibration.
What I do is when I mount the L shape aluminum piece to the Carbone top plate (803153) in the side where the outside belt is, then the cable that goes in to the receiver goes through the back of the fuel tank. The cable that attaches to the battery goes in top of the 803153, because I do not use any switch I connect direct the two cables.
I hope this can help, I now my English is not that good.
RCPANAMA
http://www.rctech.net/forum/attachme...4&d=1153916771
#3385
Hi, I am using the Xceed LiPo battery for the 720, I do have a picture this was when I was using the VRX LiPo Battery, and you can see how I mounted the Regulator in a plastic L shape piece.
RCPANAMA
RCPANAMA
#3387
This was on my 710 but I'm going to do the same thing on my 720 with the Xceed LiPo battery and regulator.
#3388
Which pretty much changes your 720 into an 08 version.
#3389
#3390
DJ,
I saw you used a Blitz Altis 2.3 body during the winternats, I'm also using this body on my Serpent 720! In your winternats setup sheet I can't find the body position.
What do you consider to be the biggest differences between this body and the Stratus 3.1?
Greetz Jeroen
Greetz Jeroen
