Serpent 720
#2401
Originally Posted by John Fontaine
Thanks. I don't think I even paid attention to the eccentrics being different left from right. Why are they different and why would results if they were backwards?
We always use it std (higher axle).
#2402
Originally Posted by Paolo M
They are different cause this way you can raise or lower the front axle (so you will have less or more steering) If you notice, if you mount it in the std way, you will have more material on the bottom of the eccentric, so your axle will be higher. The other way around if you put it backwards
#2403
Originally Posted by roadrage
will the lower axle position give you lower CG? or does it matter?
If you use the 18t optional pulley and the orange excenters, you can mount then in the low position without problems.
#2404
guys, how often do you strip belts (any of the 3)?
would you say 2 gallons a fair run time for any of the 3 belts?
#2405
#2406
720 '07 kit missing parts...
Hello to all! I've bough t a Serpent 720 '07 (#803005) and i've got a few parts missing in the kit.I list the missing parts:
-It does not came with the front CVD kit, instead it cames with normal dogbones
-front one way system as well the one way lock set to make it into a solid axle
-Bumper LeMans type
Does anyone have the same problem?? Anyway the quality looks great but especialy the CVD and the SPool as an extra where what makes me decide for this kit and not for any other brand.
Thanks in advance
Ricardo
-Bumper LeMans type
Thanks in advance
Ricardo
#2407
Hello
You probably have a 720 kit, and not a 720 '07.
#2408
What color is your chassis? The '07 has a black chassis. I believe that is the most obvious clue.
#2409
What?? but the kit nr is 803005 and e cames with black chassis, the fuel tank as a ruber o-ring!! are not these specs from the '07 kit???
Maybe QC on Serpent are not in their bets days....
#2410
#2411
I am sure they will and i'm not worried
Just want to know if this has happened to anyone here in the forum.
I've already emailed the shop were i've bought the kit to see what can they do.
#2412
#2413
Originally Posted by Sow&Steady
Depends on a lot of factors: is your track clean? are you using diff or one-way? are you using a solid front? Your driving style (some people set their brakes to the max and try to brake hard as late as possible while others drive smoother and use slightly less braking.)
using geaf diff
i'm using 3rd one way, i use the brakes quite a bit
i know its quite difficult to predict these. its just that i've had all the 3 belts now change right just before 2 gallons of run time. just wanted to know how you guys do on run time with the belts?
#2414
hi,
when using a front one way what is mostly used? as a one way or solid front axel?
Im driving on a fast track whit high speed sweepers and 2 hairpins,medium tracktion . (track = Baanbrekers Holland)
#2415
Spoiler Mounting
Hi Guys
Forgive the stupidity of the question but I have to ask
When the rear spoiler is mounted further away from the front of the car (as far back as possible) = the most amount of rear downforce? When the rear spoiler is mounted closer to the front of the car = least amount of rear down force?
The above is true for long sweeping corners. Does the above hold for quick tight corners (90 and 180 degree) type corners?
Acid
Acid
