Old 03-28-2006, 08:06 PM   #1
Default started my motor up....and the flywheel got stuck
all excited....tension mounting..the motor starts for an instant...the motor cuts off
flywheel springs flew out...apparently the flywheel jammed itself
apparently it was not on correctly...now it only goes halfway one way..halfway the other...wont go all the way around
i can feel pressure as the fly wheel turns...is this normal?
indy_rc is offline   Reply With Quote
Old 03-29-2006, 06:16 AM   #2
Brand new engine? If it is, yup it's normal. Just means your engine still has a tight pinch at the top of the sleeve still. It'll get better as you run your engine. You are also feeling the compression of the motor, always a good sign.
Get some more fuel through that engine at a rich mixture.
darkangel is offline   Reply With Quote
Old 03-29-2006, 01:52 PM   #3
soc123_au's Avatar
R/C Tech Charter Subscriber
Heat the engine with a hairdryer then start it up. The heat helps everything expand & start up easier. You will only need to do this for a tank of fuel or 2. Once the engine is run in it wont be as tight. You will still feel the pinch at TDC though.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 03-29-2006, 07:38 PM   #4
integra evan's Avatar
Send a message via AIM to integra evan Send a message via MSN to integra evan
Yeah, totally normal. In fact when I spin the flywheel with my fingers, it goes halfway each way, as I feel the compression building up. Totally normal, nothing to worry about.
integra evan is offline   Reply With Quote
Old 03-29-2006, 08:24 PM   #5
factory racer's Avatar
if its new its really normal...happened to me with both of my new motors......carfully crank it back over and make sure you don't jerk it too much......it will loosin up the more you run it....
factory racer is offline   Reply With Quote
Old 04-03-2006, 12:09 PM   #6
Does the clutch bell spin freely? If not then your shoes are all messed up, I had this happen to me. Check them, then proceed with heating the motor and cranking her up.
spcards30 is offline   Reply With Quote
Just got new motor started and its running at 200 degrees with stock settings? TEXT Electric Off-Road 13 05-14-2007 05:12 PM
OPS OP82101 .21 Nitro motor. NIB. Never started, Gold head vintagetamiya R/C Items: For Sale/Trade 2 01-02-2007 07:18 PM
Need Help, Flywheel for OS Max motor??? CDG Electric Off-Road 2 04-16-2006 01:12 PM
Help! Flywheel Stuck!!! eBoi31 Nitro On-Road 4 04-19-2002 07:03 PM
Flywheel stuck ChinBoy Nitro On-Road 7 03-19-2002 12:20 PM
SEO by vBSEO 3.5.0
