Old 03-27-2006, 03:22 PM   #1
Default Big Problem...new here.
Hey guys I'm new to this forum, but not to a vBulletin(sp) one. Also fairly new to RC cars. I have had my CEN CT-4s for about 6 months now and I just recently fixed a problem of it not running at all. Here goes another problem though if yall could help me I would greatly appreciate it.
When I turn it on it sounds great...when I give it medium to full throttle it sticks and goes full throttle and won't stop...I have to literaly rip the fuel line from the carb to stop the car. Can someone tell me what the problem is here and why it would make the throttle shoot up and stick there even when I apply brakes on my control. I would greatly appreciate it. THanks.
sloRSX is offline   Reply With Quote
Old 03-27-2006, 03:52 PM   #2
Dreddlox's Avatar
check your carb. it sounds to me like its sticking. turn the electrics on and pull the throttle and see what happens.
Dreddlox is offline   Reply With Quote
Old 03-27-2006, 03:55 PM   #3
sounds like your throttle linkage is messed up
is that a barrel or slide carb?
pictures would help me a lot because im not familiar with the car, but maybe someone else here is
impulsed is offline   Reply With Quote
Old 03-27-2006, 04:08 PM   #4
The carb is a single needle sliding. Here are some pics.
Old 03-27-2006, 04:43 PM   #5
looks like everything is set up right
you could try moving the set screw opposite the spring closer, putting more tension on the spring
other than that id say its a stuck carb
Old 03-27-2006, 04:47 PM   #6
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
Try lowering your idle slightly. Sometimes people incorrectly adjust the bottom end and raise the idle too high to compensate for the incorrect setting. If the needle is tightened too far into the carb, it can cause the slide to stick at a certain point in the range of motion.
SavageSYNTH25 is offline   Reply With Quote
Old 03-27-2006, 04:51 PM   #7
possibly a bad throttle servo.
jake alton is offline   Reply With Quote
Old 03-27-2006, 04:58 PM   #8
I appreciate it guys. I will try the idle screw out tomorrow...I backed it out a little so I will see if that works. If not then option two (new Carb or New Servo)
Old 03-27-2006, 05:04 PM   #9
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
you should always use a rubberband as a return to bring the throttle back to idle for this reason. a good servo is a good investment too
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 03-27-2006, 05:21 PM   #10
Yea I got you on that rubber band thing...its just that I can pull back the throttle and it will go into regular position, but the car is still out of control with the speed...
Old 03-28-2006, 06:11 PM   #11
ssc-rc's Avatar
try cleaning it it looks like ya been riding the weeds,anyway run it and spry it to see if ya got an air leak somewherew-d or lite oil then clean it again.
ssc-rc is offline   Reply With Quote
Old 04-03-2006, 11:14 AM   #12
So wait when you pull the servo throttle back it is still going crazy? If thats the case you need a new carb
spcards30 is offline   Reply With Quote
Old 04-03-2006, 11:15 AM   #13
I mean when you try to close it with your fingers does the engine slow down, if not you need a new carb.
Old 04-05-2006, 12:59 AM   #14
luketob's Avatar
have you checked the servo horn make sure the teeth inside the horn is ok, also check your EPA on your radio..if you did checked them then it could be your carb.
luketob is offline   Reply With Quote
Sponsored Links
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 06:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 07:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 05:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 03:08 AM
SEO by vBSEO 3.5.0
