Old 02-15-2006, 06:12 PM   #1
HPI 2nd gear
I promise this is the last time I'll post this topic.
I give up. My RS4 2spd will not shift. I've bought every new part I can. Adjusted the shift point from all in to all out. Leaned out my engine to increase RPMs. Nothing works.
Any last suggestions????????
HPI GUY is offline   Reply With Quote
Old 02-15-2006, 06:17 PM   #2
bummer... All i can say is make sure you used thread lock and all your set screws are tight, Because i had this problem tried leaning i decided to open up my car and i saw my set screws loose so i added thread lock and it was fine... hope this helped
Modifiedrs4evo3 is offline   Reply With Quote
Old 02-20-2006, 01:17 PM   #3
Rapid Roy's Avatar
Is there somebody locally that can help you out? Are your sure that you assembled everything properly? Also, make sure that you are adjusting the correct screw. One tightens the unit to the shaft, the other one is offset and adjusts the shift point. Make sure that you didn't loose the little ball that goes into the hole before the spring.
Here's how I start off adjusting. With the 2 speed disassembled, insert the ball, spring and adjustment stud into the correct clutch hole. Hold the clutch hole so that the finger rotates out of the housing. Now slowly tighten the adjustment untill the finger fully retracts into the housing. Give it another 1-1/2 to one full turn more tighter. Now assemble the 2 speed and install in the car. Start up the car and slowly rev it up. You should be able to hear and see it shift as you do this. If it doesn't, losten the adjusting screw 1/4 turn at a time, testing in between. Keep doing this untill you hear it shift. Once it does, you can fine tune the shift point to suit track conditions and gearing.
Rapid Roy is offline   Reply With Quote
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 09:03 PM
R/C Gear FOR SALEPleanty New and some used off road gear DirtRacer Australia For Sale/Trade 1 11-17-2007 02:45 AM
Pinions, Radio Gear and Battery Gear d4_racer Australia For Sale/Trade 9 09-18-2007 01:07 AM
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 06:37 PM
mugen 2nd gear housing and derlin gear for sale. aznxlionhrt R/C Items: For Sale/Trade 0 03-27-2003 06:31 PM
SEO by vBSEO 3.5.0
