Clutch bell bearings
+1 for TKO. Will last for gallons.
TKO
The TKO's are radial thrust bearings if I recall correctly. The bearing race has a deeper groove in it I believe, and they handle both the radial and axial loads. Standard bearings will only tolerate the radial... or axial... Not sure but they won't hold up to both and a clutch bearing needs to be able to handle both types of loads.
I've used the J&T ultimate bearings and they're better than standard ones for sure but never have ran them as long as the TKO. That said they I haven't had them fail I just have not built up my confidence in them to the level I have with TKO. They may be just as good or better.
TKO special clutch bearings. As stated above they are made to handle the forces the clutch puts on them. Just make sure you install them correctly. They have a blue seal on one side those need to face each other once installed.
Inside bearing blue seal faces out
Outter bearing blue seal faces in
https://youtu.be/h2lCJZxGH6k
+ YouTube Video | |
+ YouTube Video | |
The J/T seems cool, but just 2 weeks a go. I seen the dude that is good driver blow them.
I blew the J/t clutch bearings.. First the inner one on one race day..about a quart of fuel replaced. next race day outer bearing blew about a quart of fuel. replaced. Went 3 quarts of fuel and checked bearings inner bearing destroyed... outer still good. Trying the TKO bearings now. First race day this past weekend. Going to take her apart and check. On another note. J/T other bearings have been really good.
Interesting ....i personally use jt ucb 5 x 10 x 4 and have never had one fail still
I use buku komposite shoes on buggy and alu. 6061 on truggy .....no blowing out or re oiling
I use to use tko for years then couldnt get a hold of peter any more ....tried jt ucb ....done deal
Tyler is awesome guy as well
I've had two sets of TKO and both of them lasted less than a weekend of bashing. And I tried the Acer's special clutch bearings also. Maybe it was my poor clutch bell shimming settings at that time, I don't know exactly. But since I start using proper bearings I've had zero issues. My advice? Buy only brand bearings, for example I'm using EZO made in Japan, same set for more than a year and they show no signs of wear. My 2 cents.
