Tekno NB48.4 Thread >
Tekno NB48.4 Thread
Like Tree71Likes
Tekno NB48.4 Thread
    Hide Wikipost
Old 07-07-2017, 08:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48.4 Thread
Last edit by: MattDub
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Aluminum Servo Horn:
-TKR5251B (23T)
-TKR5252B (24T)
-TKR5253B (25T)
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (Rear)
This car is very durable. Here are the spare parts that we recommend you keep on hand:
Tips and Tricks
Vehicle Setup Adjustments and Build Tips
Tekno RC Instructional YouTube Video Playlist
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on our website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Setup Sheets:
Setup sheets for all of our vehicles can be found here.
What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Print Wikipost
Old 08-08-2017, 02:06 PM
  #166
Originally Posted by teknotank
Got mine all built up last week tried an old novarossi p5 but I just could not get it to fire up on my starter box. Unsure on whether my pack just hasn't got the power to start it. I have an old SMD starter box and was wondering what boxes people are using with their nb48? I had to shim the motors and wheel up in my box in order to get proper contact with the flywheel.
Has anybody else found that the bolts that secure the wing to the mount are a pain in the ass? I didn't do mine up 'tight' as such and even so when I tried to remove the wing the little nyloc nuts simply spin in the plastic and don't 'lock' like they should , has anyone else found this?
Cheers,
Nick.
Hi teknotank,
Most people use the blue Ofna box. It's very robust and turns over the most stubborn engines. It does need adjustment to fit our nitros but nothing major.
Odd that the nuts would spin in the mount. Would double check to make sure they aren't cross threaded. They should thread in easily and typically do not spin. Maybe over tightened?
MattDub is offline
Old 08-08-2017, 09:19 PM
  #167
Will the Kyosho box work with the buggy? It looks like there is a lot of adjustability available with that box.
TaGWolfgang is offline
Old 08-09-2017, 02:34 AM
  #168
teknotank's Avatar
@mattdub thanks for the reply.
I did just chuck the Nova engine straight in with the old mugen mbx5 flywheel so that was probably another issue. But I'll measure the flywheels today and see if there is any different. I think I'm going to go for the blok engine / pipe setup anyway I just wanted to see If the old Nova would kick into life!
As for the wing mount, no I didn't overtighten. The captive nuts as such, just aren't captive and therefore spin, I have had the same problem on the front hub too.
I did manage to get the front camber link undone and was cautious tightening back up yet still spins inside the recess where out should be locked off.
The rest of the kit, just like my SCT went together perfectly. Its only a minor annoyance just means having to remove the wing from the other bracket but when I do manage to get the to wing off I'll make sure the captive nuts are wedged into place and cannot move.
teknotank is offline
Old 08-09-2017, 04:46 PM
  #169
teknotank's Avatar
Hoping to get mine up and running before the UK summer is out. Just need an engine to replace the 10 year old nova what is currently sat in there + 2 new servo's.
It's just an ARTR shelf queen at the moment
TWO by Nicholas Simpson, on Flickr
ONE by Nicholas Simpson, on Flickr
slodsm, hairymuffin and MattDub like this.
Old 08-16-2017, 05:46 PM
  #170
R/C Tech Elite Member
slodsm's Avatar
Trader Rating: 33 (100%+)
Finally got around to cracking open the box on my nb48.4 to start building it.
I have to say, I’ve been playing with toy cars for a very long time and I’ve built everything from kyosho, X-ray, losi, AE, and on and the small things that tekno does like including thread lock always impress me. I love these freakin cars.
slodsm is offline
Old 08-30-2017, 03:03 AM
  #171
Default Body used
Are most people using the stock body or an aftermarket body and why?
user1 is offline
Old 08-30-2017, 05:00 AM
  #172
Most stay with the stock .4, Ryan and Joe both use it. Your pit guy will love it and is easy to drive. When pitting it's impossible for the tank pull to get caught behind the body and the fuel gun pretty much finds its own way to the tank. The downforce characteristics are very neutral, not too much steering or rear grip.
msalinger likes this.
MattDub is offline
Old 08-30-2017, 05:31 AM
  #173
Your.4 looks crazy cool ! May I ask what wheels are those.Im thinking of buying another.4 and tires? Tnx in advance
batremi is offline
Old 08-30-2017, 08:29 AM
  #174
Trader Rating: 14 (100%+)
I have noticed in the latest set up sheets that Lutz is using a Kyosho wing. I am curious to know what the benefit is over the stock wing. Thanks!
msalinger is offline
Old 08-30-2017, 01:19 PM
  #175
He mostly likes it because it has less downforce at high speed.
MattDub is offline
Old 09-12-2017, 07:22 AM
  #176
cjwilly's Avatar
Default VRP Gamechanger pistons
Is anyone having any luck with these? What's your setup?
cjwilly is offline
Old 09-13-2017, 12:41 AM
  #177
slodsm's Avatar
I’m using lutz’s wicked weekend setup but a bit softer in the shock oil and it is utterly money on my home track. Hard packed indoor, med/high bite depending on how long the layout has been the same, bumpy but not blown out.
Best nitro buggy I’ve owned.
teknorc likes this.
slodsm is offline
Old 09-28-2017, 03:28 PM
  #178
slodsm's Avatar
Got both of them ready to rock for RC pro round 5 next weekend, going to be a whole new track surface so tire choice will be completely out there but tire wear should be less and I threw a fresh chassis under the the EB48.4 and maybe this one will live longer as well with the pete moss mixture that's going in with the clay.
bgP9QTVQTmSkwDrv4LDVRQ by Jeremy Sensing, on Flickr
slodsm is offline
Old 09-29-2017, 08:51 PM
  #179
i am not a fan on the stock body on my nb48.4 whats a good after market body for it
MadMick is offline
Old 10-01-2017, 09:00 PM
  #180
Trader Rating: 61 (100%+)
Leadfinger Racing
mr240 is offline
