Losi 8IGHT Nitro 1/8 4WD RTR Buggy - v.2016/17 >
Like Tree38Likes
Old 06-23-2017, 02:31 PM
  #106
While i had half car in my hands i should have changed the frame too, i'll do it at some point ...
Well i hope i didnt do any mistake lol
Guyon is offline
Old 06-23-2017, 02:34 PM
  #107
PS see what i did at the pipe? And the engine :P ?
Guyon is offline
Old 06-23-2017, 07:21 PM
  #108
Hmmm...
Engine I see you got rid of the pull start rope
Pipe I see 2 zip ties on the coupler lolol
Evoking1230 is offline
Old 06-24-2017, 12:23 AM
  #109
You know that RTR stands for "ready to replace"
buster8787 is offline
Old 06-24-2017, 02:34 AM
  #110
Originally Posted by Evoking1230
Hmmm...
Both solutions worked for me :P
Guyon is offline
Old 06-24-2017, 04:13 PM
  #111
only thing I've replaced on this RTR are a few zip ties on the coupler, an air filter(std. maintenance) and a glow plug.
Old 06-25-2017, 10:53 AM
  #112
Hey Guyon,
I noticed you use the starter box. Does it line up perfect because I noticed the flywheel is a bit up in the cutout then Im used to. My son's Kyosho RTR the flywheel is right there.
I want to get a starterbox asap but I don't want to get the engine mounts, back plate, etc just yet, if at all. Eyeing that Reds W7 w/ tuned pipe for a wedding anniversary gift lolol.
Old 06-25-2017, 02:25 PM
  #113
I use the Robitronic one
I just need to move the car a little bit to a side then it works perfectly.
Its not the cheaperst though.
How did u set the shocks? Can you post a pic? Mine seems to be a bit meh, idk how to change them though... for sure i need to rais a bit the back
Guyon is offline
Old 06-25-2017, 08:20 PM
  #114
^^^Thanks. SO the starter wheel makes good contact with the flywheel with no issues?
As for the shocks, when you want to raise or lower the ride height, use the black round "spacer" and either turn it clockwise or counter clockwise, depending on which direction you want to go.
Old 06-25-2017, 11:44 PM
  #115
Takes a bit to position it the first time, then it just works perfectly
I'll have to play around with them a bit to find a good setup!
Guyon is offline
Old 06-26-2017, 12:12 PM
  #116
Start with front arms level in relation to the ground. Rear arms can be level or slightly below level for a bit more rear traction.
Old 06-26-2017, 12:30 PM
  #117
I redid the shocks too, the rebound on 70% was not optimal i went for a 100%
Guyon is offline
Old 06-26-2017, 07:29 PM
  #118
so those tires that come with the RTR work awesome on wet/damp & muddy dirt! Raced yesterday at a makeshift track the locals use. There was 10 of us on a tight technical, damp wet track with a few small puddles here and there. I made a change to the wheelbase(spacers in back to shorten the wheelbase) and it was dialed! I was able to TQ and win by a whole lap! 30 minute main. I got into the zone in the 2nd half of the race and essentially put "my head down" and ran away with it at a blistering pace!!!
The new shocks and towers with the extra adjustments really helped. THe rear was planted. THe local guys running full out kits couldn't believe it started out as a RTR. Its pretty much a 3.0 with a pull start! lolol
Even my son couldn't believe how fast it was!
Love this buggy. I think I want a truggy now. And a E-buggy.
mental note though...don't race on these conditions again. Its a PITA to clean
Old 06-26-2017, 11:37 PM
  #119
lol sick, gz Evoking
Guyon is offline
Old 06-30-2017, 02:02 AM
  #120
Random question :P Which nitro fuel do you use?
Guyon is offline
