Old 05-30-2007, 12:20 AM   #1411
Turbine_au's Avatar
Thanks for that.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 05-31-2007, 07:09 AM   #1412
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Steering
Hi all the MBX5 owner, I need advise on the right way to put the steeringhook on the servo horn. Pls refer to the pic. It this is a right way I put or I need to put oppersite? The holder touch to the servo tray when I turn.........
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 05-31-2007, 07:16 AM   #1413
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I have the linkage on the other side of the arm.
infanterene is offline   Reply With Quote
Old 05-31-2007, 07:26 AM   #1414
tkhoo's Avatar
Oh yeah...it call linkage. Mean currently you are running oppesite way and it running fine? That good to hear. Will move it tomorrow. Thanks.
Old 06-03-2007, 06:17 PM   #1415
Capelracer's Avatar
Any suggestions for a lipo receiver pack to use in my MBX5Prospec??
Capelracer is offline   Reply With Quote
Old 06-03-2007, 06:37 PM   #1416
Capelracer's Avatar
MODERATORS!!! Move us to Nitro Off-Road plz
Old 06-04-2007, 08:59 PM   #1417
Steve Torrey's Avatar
capelracer, check out h/t batteries or www.commonsenserc.com both make a real nice reciever battery.
Steve Torrey is offline   Reply With Quote
Old 06-05-2007, 12:17 AM   #1418
Capelracer's Avatar
Cheers Steve
Old 06-06-2007, 09:27 PM   #1419
HHHOGGG's Avatar
I have one in my 5R and one in my 5T and I also use their starter box batteries. Great stuff and super light!
http://www.htbatteries.com/
HHHOGGG is offline   Reply With Quote
Old 06-12-2007, 09:58 AM   #1420
slow coach's Avatar
just a quick question on sanding the diff cases, do you have to run 2x seals or can you get away with the 1, im wondering if the sanding will cause any binding with 1 seal or are we talking about a small amount of material which wont make enough difference, my diffs leak and the grease comes out through the bearings im guessing this is a o ring issue rather than the case seals leaking? I have ordered some 5x1.5 o rings to hopefully improve the seal but i have some standard ones just in case they just need some grease, i read the types of grease to use mugen/mobil etc what about silkolene RG2 its a red grease A super high melting point lithium complex synthetic waterproof racing grease, designed to meet the exacting requirements of competitve use
High stress, high cling formula does this sound ok also.
Cheers
one last question on running lipo with 7 volt regulater how will this effect servo life if designed for 6 volt
slow coach is offline   Reply With Quote
Old 06-12-2007, 02:01 PM   #1421
Registered User
Default Mugen Aluminium
Hi,
Anyone recommend any other aluminium parts for the 5r apart from the Rear Tension Rod Mount and the radio tray mount, the radio tray tends to flex a bit when the brakes are applied.
Cheers...
Loop&Roll is offline   Reply With Quote
Old 06-12-2007, 02:34 PM   #1422
Crim3Wav3's Avatar
ive been running the Fioroni radio tray mount, Fioroni steering servo mount, and the aluminum standoff radio tray support. The pretty much keep the steering servo case from twisting/tweaking/getting f'd up....
I also use the Racer's Edge sway bar mounts, front and rear. They wont break if you get rear-ended and the screw wont strip out....just be sure to use locktite once you get it setup!
Crim3Wav3 is offline   Reply With Quote
Old 06-14-2007, 10:06 PM   #1423
TonysScrews's Avatar
Cheers
Sanding the cups takes off barely anything (maybe .001") so you can still use one gasket. Not sure about that grease. I know the Mugen Super Grease, Mobil 1 synthetic grease and the Maxima synthetic grease all work well. I do not see the Lipo with 7.0 volt regulator affecting servo life at all. Fully charged hump packs make more than 6 volts as well, but drain off fast. The Lipo is the SHIZZLE!
TonysScrews is offline   Reply With Quote
Old 06-15-2007, 08:22 AM   #1424
Default Help a Mugen noob out
I recently got a MBX5R kit and I've been slowly been putting it together. Reading previous posts I built the diffs without the 3mm spider o-rings and dumped thick amounts of mobil 1 grease on the diff gaskets and 5mm orings. Diffs now feel smooth. However, when I install them in the diff case with the pinion gear, it's not so smooth. The manual doesn't call for any shims and the kit didn't seem to come with any so is it supposed to feel a little "gritty?" Also I ended up using red loctite on the set screws in the CV driveshafts did I screw up? Thanks in advance!
Losi 8ight-T 1.0 OS Speed JR 9000S/T
Losi 8ight 1.0 C6BB7T 2045 086 Hitec 5997TG/JR 9000S
Losi 22 Tekin RSpro 8.5/JR9000S
All controlled by 3PK/FASST
magbarn is offline   Reply With Quote
Old 06-15-2007, 11:30 AM   #1425
By the way guys i am thinking i will be putting up my 5R tonight ready to go. V spec, Lipo 7v regulator, os pipe, jp2 pipe and king headz rear mounts. Just needs a reciever. Wanted to give you guys first shot as well as ask what a fair price is. Just no time for Nitro right now.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
