Old 05-15-2007, 09:23 PM   #1396
getting ready for this weekend. lol brake set ups are better now (bigger diff than i thought need between real loomy surface from hard packed surface) and had to remove 2 burrs from my clutch shoes on my prospec. odd how those effect off power coasting and jumping. lol jump and in mid flight the wheels would slow way down into a nose dive lol.
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-16-2007, 04:49 AM   #1397
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
hay just want to post my setup works great for me
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-16-2007, 04:53 PM   #1398
gasman517's Avatar
my kids buggy has the same setup except for 5,5,3 diff oils
gasman517 is offline   Reply With Quote
Old 05-21-2007, 02:10 AM   #1399
TonysScrews's Avatar
I take it you're using aftermarket bushing for the upper arm mount?
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 05-21-2007, 02:26 AM   #1400
im using the brass one's from Carolinas RC
Futaba
Mugen
Novarossi
Byron's
Old 05-21-2007, 02:08 PM   #1401
Crim3Wav3's Avatar
The how do you have the upper arm centered? Is only that bushing plastic?
Crim3Wav3 is offline   Reply With Quote
Old 05-21-2007, 06:54 PM   #1402
they are BRASS and you buy an extra centered one so you can run them front and back no big deal
i brought one pack as pictured and to extra one centered and one off center so i can have the option to fine tune it to my likeing
Futaba
Mugen
Novarossi
Byron's
Old 05-26-2007, 07:10 AM   #1403
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default MBX5
Hi all, I just bought a 2nd hand buggy which mention at above. Currently I thinking of to rebuilt it with change all the diff oil. Before I open up the diff what are the thing I need to prepare? Do I need to prepare gasket? Do the diff need gasket in between? What is the weight should I put f/m/r.
One thing need advise. Whan I use hand to turn the wheel, I can hear the diff metal sound like metal hit with metal is this mean inside the diff already less oil?
Please advise and thanks in advance.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 05-26-2007, 09:11 AM   #1404
Turbine_au's Avatar
Hey guys, just bought this: Brand New Mugen MBX5-R, With Novarossi Plus 21-5, Ninja Pipe, GRP tyres!
Just a couple of setup related questions from the setup sheet:
1. Rebound stop, is this droop? If so, is it just a case of placing a wheel under the car and measuring how far the upright sits of the table?
2. Upper Arm position: Are the positions shown done using inserts?
3. What does E0106(A-D) refer to?
4. How is rear toe and anti squat set?
Also, what things should I be keeping a close eye on, other than the usual checking of threadlock etc. I've heard to ensure the servo saver gets a good clean and lube and to super glue the pillow balls? Things like that...
Thanks.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 05-27-2007, 06:47 PM   #1405
Default MSR truggy
Hi guys,
I'm new to offroad and been looking around for a truggy kit...
Came across a MSR truggy which is converted from MBX5...
Is it any good?? or should i go search for a actual truggy with long arms not offset wheels...
thanks
ck
ck960 is offline   Reply With Quote
Old 05-27-2007, 07:01 PM   #1406
Without a doubt get the 5T kit not the MSR conversion.
PAPA is offline   Reply With Quote
Old 05-27-2007, 08:49 PM   #1407
rcmike's Avatar
Trader Rating: 40 (100%+)
Default ck-960
IMO- shop for the mbx5t. i think you will be happier with the purpose built truggy.
rcmike is offline   Reply With Quote
Old 05-28-2007, 06:54 AM   #1408
Default MSR truggy
Thanks guys, anymore input??
anyone use one to race b4 and share some experience??
thanks,
ck
Old 05-29-2007, 09:52 PM   #1409
Turbine_au's Avatar
Originally Posted by Turbine_au
Hey guys, just bought this (MBX5-R): Brand New Mugen MBX5-R, With Novarossi Plus 21-5, Ninja Pipe, GRP tyres!
Thanks.
Anyone?
Old 05-29-2007, 10:16 PM   #1410
Slippery's Avatar
Thumbs up
Anyone?
Turbine ,
1.Rebound stop is the Droop measure use new rims under the chassis and measure under the uprights front and rear
2.Upper arm Bushings are used flip the bushes to suit E0106a-b or E0106c-d
3. E0106a-b or c-d refer front upper arm mount position ,if you look closely at the under side of these plastic pieces they are marked a-b and c-d take notice of the hole placement ,these are for roll centre changes.
4. Rear toe thru back plate should be marked
5. rear anti squat Alloy plate before rear diff housing use bushes to get anti squat setting .
download a set-up sheet from Mugen and it is fairly easy to work out
cheers
Slippery is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
