Old 03-11-2007, 10:35 AM   #1156
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
One other pretty cool thing to check out is...
http://www.carolinasrc.com/webstore/...?idproduct=690
Holy crap...it's like a new car...no slop at all, still free. I have no idea how well they holdup over time, but it's so nice right now.
I've also had http://www.carolinasrc.com/webstore/...?idproduct=404 and
http://www.carolinasrc.com/webstore/...?idproduct=453
on the car for quite a while just to eliminate some parts. No e-clips, less hardware, no stripped-out pin mounts.
My car was pretty tired when I got it, so most of the hop-ups I've bought thus far were to replace worn out parts or make the car simpler (or both). I've never really broken anything on it, aside from an arm or two.
Turbo Joe is offline   Reply With Quote
Old 03-11-2007, 01:37 PM   #1157
nobike's Avatar
Trader Rating: 147 (100%+)
Originally Posted by Jon Kerr
The car was really good tonight. I did add a little droop to the rear like you mentioned for the main and it was even better than in the first round. I couldn't believe how good my time was in that round. Thanks for the tip. I'll probably see you back at Revelation in a couple of weeks.
i have more tips if you want to try them, i saw you had the lead in your race for awhile, there has been alot of hacking at REV lately.................
nobike is offline   Reply With Quote
Old 03-11-2007, 01:58 PM   #1158
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I had a big lead in my race and pitted early when I was coming up on lapped traffic. (12 miute race) I was 1 turn behind the guy who took the lead but hadn't pitted when I lost the steering servo. Oh well. The car was good and I felt I was driving pretty well too. Traffic was a little tough but not too terrible.
Jon Kerr is offline   Reply With Quote
Old 03-11-2007, 06:06 PM   #1159
I have the mbx 5 prospec, and I am going to install the 48 tooth spur gear (muge0218) will I need any other parts from the "r" kit to make it fit? I just want to make sure I order everything at the same time I'm going to need! Thanks! I am not sure if its a direct fit or not.
madlosi79 is offline   Reply With Quote
Old 03-11-2007, 08:01 PM   #1160
TonysScrews's Avatar
The 48T spur gear will fit the MBX5, MBX5 ProSpec, MBX5R and MBX5T with no issues.
as for hopups, check out the light-weight pillow ball options out there. The stock pillow balls are steel and weigh 50 grams. The lighter options out there knock off about one ounce (28 grams) and that is unsprung weight. The car handles better and has better traction with less unsprung weight.
You can get them from: DaceMfg, Lottaballs, CBRS, K-Factory and Thunder Tiger. The DaceMfg and CBRS balls are steel shaft with aluminum ball that has been teflon coated. The Lottaballs use a steel shaft and polyethylene ball (with graphite). The K-factory ones are Titanium. Not sure what the Thunder Tiger ones are made of?
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 03-11-2007, 09:10 PM   #1161
gasman517's Avatar
HELP!!!I think a bunch of guys run ninja engines in this forum im looking for a idle screw for a bo1 engine and no one has it I need it in my hand by thursday or my son is screwed for a big race this weekend and his 5r needs to race If anyone can help let me know , Much thanks Paul
gasman517 is offline   Reply With Quote
Old 03-11-2007, 09:43 PM   #1162
RYAN BARNES's Avatar
PM me your mailing address and I'll send you a Ninja idle screw out, not sure if it will make it by thursday or not? But I'll give it a shot!!
RYAN BARNES is offline   Reply With Quote
Old 03-11-2007, 09:56 PM   #1163
gasman517's Avatar
pm sent Thanks bud!!!
Old 03-11-2007, 10:06 PM   #1164
nutfluff's Avatar
Send a message via AIM to nutfluff
Speaking of screws...does anyone know the screw size for the Ninja that connects the cooling head to the engine? (The four that go in the cooling head.) Thanks in advance!
nutfluff is offline   Reply With Quote
Old 03-12-2007, 08:43 AM   #1165
Trader Rating: 14 (100%+)
probably 2.5mm like all motor screws.
o.s. power is offline   Reply With Quote
Old 03-12-2007, 04:07 PM   #1166
MaxxBashers's Avatar
Trader Rating: 107 (100%+)
Does anyone know if the TTR 48t spur gear is the same as the mugen? I heard they were the same and the TTR is only $13? I run the TTR option brakes and lightened pillow balls, but not sure about the whole spur gear thing. Anyone try this yet?
Eric "EJ" Jordan
MaxxBashers is offline   Reply With Quote
Old 03-12-2007, 04:48 PM   #1167
I'm pretty sure the TTR has a larger outdrive shaft diameter. The Mugen is only 5mm.
Tony P.
Tonys Screws LLC
Old 03-12-2007, 05:11 PM   #1168
Anyone looking for a Mugen off-road starter box I have one like new for sale in the Buy/Sell forums. Comes with two 3,000mah NiMh batteries with Dean's Plugs on them.
Tony P.
Tonys Screws LLC
Old 03-12-2007, 05:18 PM   #1169
Jon Kerr's Avatar
I wish you had that for sale 2 months ago. I looked everywhere for that starter box. I guess my Kyosho box works fine but I really like the Mugan.
Old 03-12-2007, 06:41 PM   #1170
LOL Jon. The box is sold already. Man was that quick!
But I do have another one for sale that is older. Will take less for that one.
Tony P.
Tonys Screws LLC
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
