Old 02-21-2007, 08:41 PM   #1066
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Ryan. I'm running the Ninja .21 with the Ninja pipe too. What will the difference in power band be if I put the JP3 pipe on it? I know the JP3 is supposed to be the best of both worlds, bottom end and top end. But how does it compare to the Ninja pipe?
Jon Kerr is offline   Reply With Quote
Old 02-21-2007, 08:43 PM   #1067
RYAN BARNES's Avatar
Yeah I really like those style throttle/brake kits, Sportwerks makes one that looks exactly like the Dynamite, you can pick those up for around $8-10. PM me you email and I can send you a good MBX5 setup, it may be tomorrow I'm off to bed!
RYAN BARNES is offline   Reply With Quote
Old 02-21-2007, 08:46 PM   #1068
Jon -I'd leave the Ninja pipe on the Ninja motor unless your needing to calm the buggy down for indoor racing, I run this setup and it rips!! As for the JP-3 yes it gives good smooth all around power, but just not the rip of the Ninja pipe.
Old 02-21-2007, 09:03 PM   #1069
Jon Kerr's Avatar
That's what I wanted to hear. I'm really enjoying this nitro stuff but as an electric guy, I have a lot to learn still.
Old 02-22-2007, 01:10 PM   #1070
B.P.'s Avatar
Default ninja pipe
Performance wise the Ninja pipe with long header rocks. Durability is another story.
B.P. is offline   Reply With Quote
Old 02-22-2007, 02:35 PM   #1071
Trader Rating: 42 (92%+)
hey Ryan can you email me that set-up
icemandolmite@aol.com
do you have a couple for different tracks
or do you the same everywhere
thanks
icemandolmite is offline   Reply With Quote
Old 02-22-2007, 02:47 PM   #1072
What bearings do you guys recommend?
Has anyone got experiance with Acer Bearings? What kind of maintenance do they require? Ultrasonic clean and then bearing lube? Can their seals be removed?
stamko is offline   Reply With Quote
Old 02-24-2007, 09:57 PM   #1073
Jon Kerr's Avatar
Has anyone run the fiberglass brake disks or the carbon fiber brake pads? I'm using the stock blue pads and steel disks and was just wondering what the different feel will be.
Old 02-24-2007, 10:39 PM   #1074
rcmike's Avatar
Trader Rating: 40 (100%+)
Stamko- check out {www.avidrc.com} Jon- i run the Avid Indo,give them about one lap{to put heat in the disk} and they will stop exactly where you wanted too.Both products are good.More info on there site.
rcmike is offline   Reply With Quote
Old 02-25-2007, 06:34 AM   #1075
TonysScrews's Avatar
I used to run the Cradock brake discs on my MBX5, but now I use the TTR "option" brake discs on my my Mugens.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 02-25-2007, 04:34 PM   #1076
Nitroaddicts's Avatar
Where do you get those?
www.NITROADDICTS.com
Get Free T-Shirts with Nitro Points!
Need Track TShirts?
http://www.facebook.com/AmericanGFX
Nitroaddicts is offline   Reply With Quote
Old 02-25-2007, 05:13 PM   #1077
Trader Rating: 14 (100%+)
+1 on those thunder tiger option disks, ridiculous braking power!
o.s. power is offline   Reply With Quote
Old 02-25-2007, 05:43 PM   #1078
kaotickc's Avatar
Trader Rating: 43 (100%+)
Do you run just the plate or do you have to run the fiber pad with those?
kaotickc is offline   Reply With Quote
Old 02-25-2007, 06:34 PM   #1079
just the metal plate/caliper, The TTR disks are fiber, but they have an aluminum frame/heatsink, when you see them you'll know what I'm talking about. They are trick.
Old 02-25-2007, 06:59 PM   #1080
kaotickc's Avatar
What would the difference between the Ninja and the JP3 be? The ninja pipe is a 3 chamber pipe also. I just got a new ninja and was thinking of ditching the JP3 for a ninja, but I dont like the ninja not being hardcoated or a re-enforced stinger. I mean if they are both 3 chamber pipes, there shouldnt be that much difference should there?
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 10:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
